How to test a Bi-Directional Triode Thyristor
  • Thread starter Thread starter Planobilly
    Test Thyristor
151 replies · 21K views · last reply
NascentOxygen said:
It might be better to leave it as a thumbnail, not display it inside the post, then readers (those who want to see the detail) can open the image in a separate browser tab and magnify it to heart's content.
What a good idea !
I'll remove that last post and try it.
Here's the cropped one, 2.96 mb. Thumbnail only.
Edit - removed unneeded image to save disk
I'll go remove that last one now, to save 3 megs of magnetized iron oxide .
Hmmmmm looks like it gets downsized to 960 pixels anyway
shrunk from 2.96 megs to 207.7K during "Upload"
That works well.
I can download the file and work with it as I like.
Thanks,
Billy
Members who don't use a tablet could be forgiven for assuming that when using a tablet we can just keep spreading the image to magnify it almost without limit. Not so, at least not on my Android 4.4
Well before a small image like this schematic becomes readable, the PF page headers MENU, MY PF, INBOX, etc., enlarge and move down to cover over the viewing area!
:H:H:H
I must instead open the pic in its own browser window.
Just to clarify the situation a bit:
That would be fine, even tablets have PDF readers. HOWEVER I can't find a way to post the full size PDF. Compressing and zooming doesn't work because the readability/detail is lost in the compression, and zooming something that isn't there doesn't help.
The original page size of the image was roughly 8.5x11 but if the resolution is taken below about 360 DPI the small printing and details, like whether a transistor is NPN or PNP, are lost.
EDIT: You guys are fast! The time it took me to write this, there were four more posts.
Correct, but you're running up against our 3MB attachment limit? If you need to make available a file larger than that limit, the only way is to store it on an outside host (of which there are many available for free) and to include the URL in your PF post.
The big drawback in using a hosting site is that at some future stage it's likely that either you or the host will drop the file, and then the PF thread of which it was an integral part becomes next to worthless.
Planobilly said:
That works well.
Thanks,
Billy
It's not as clear as Tom G's rendition
i'll email that to you
Thanks Jim
I assume there is some site somewhere that PDF's can be stored on that anyone can access. I am looking now.
I must have missed the 3MB limit. All I saw was image limit of some pixel count. If your file size limit is 3MB I'll see what tricks I can figure out to get there.
Tom.G said:
If the upload is successful at 2.998MB, here is the enhanced Carver M1 schematic in PDF format.
Works great - You 'da Man !
I guess the only thing remaining for this side issue is to get a link in or near the OP, rather than buried 7 pages deep.
Now if we could just get schematics that actually tell us what we want to know!...lol
I am off to bed.
Cheers,
Billy
If only!
All my Wizard contacts have either died or left town.
I have added a link in the OP. Which old links/attachments should now be removed?
i cleared out mine, hope i got 'em all.
Thanks!
Link in post 131, and copied in 134, is valid but points to an outside repository. You should probably contact owner of post 131 for his desired resolution.
For my post 134 (referencing 131), I don't like to remove a 'job well done' comment but it gets confusing to leave it as is. I will leave the final determination to you and post 131 owner.
My post 130. At your discretion, the second quote thru end of message may be deleted. This may avoid possible confusion for those trying to follow this mess in the future.
And this post itself can confuse the heck out of folks, but I couldn't find how to PM you. Maybe it too should be deleted.
I would delete post 131 but I don't know how you do da!
Anyone who can delete stuff can delete anything I posted without issue and this post also when we get this mess cleaned up!
I know the internet is a strange place but I am not one of those people who get upset about much of anything. Well...there is that big fish I lost...lol
Cheers,
Billy
Hmmm I'm slow but the lights are beginning to twinkle on.
Text from a service manual titled High Rail Voltage Adjust, listing steps and DC voltage checks for D126, D128, D130, D132 and IC301 pins in inverting and non-inverting versions.
So SVR301 adjusts the regulator that fires triac... they tell us to adjust by measuring the 100 volt line
but the regulator senses 4 voltages, ±60, -100 and i think +100...
Schematic of an op-amp regulator circuit with an LM-style op-amp, labeled resistors R311 62K, R315 680, R312 680, R310 62K, R309 100K, R305 5.1K, R306 6.8K, R308 100K, SVR301 5K, ZD301 3.6V, C301 25V, R304 51K, R303 100, R302 1K, R301 4.7K, D302, D301, D308 and R332 4.7K, plus red +1.3V and green -1.3V markers.
Pin 5 should be about -1.3 volts because of a milliamp each thru R308 and R310 from -100 and -60 volt supplies
so pin6 must be driven to match pin5
junction of R309-R311-R313 should be similarly around +1.3 because of a milliamp each through R309 and R311
(though i haven't yet found how +100 gets to R309)
that suggests around a half milliamp entering pin 6's node through R305, 2.6V/5.1K = ~.5ma
and that half milliamp has to exit the node through R306-SVR301
so there's our balance ... ZD301 is voltage reference against which supply voltage is balanced.
I submit -
If + supply voltage increases, that makes pin6 more positive, lowering opamp output,
and that decreases current through R301 and photodiode
retarding Triac firing angle to restore voltage...
That's the closed loop ?
R303-D302-C301 allows regulator to raise voltage faster than it can lower voltage
D301 protects the photodiode against reverse voltage (it's only rated 5 volts reverse)
What signal comes in through R332-D308 i haven't figured out yet.
Anybody else know ? I'm a plodder, as you know..
whew out for tonite
jim hardy said:
Anybody else know ?
Looks like the right and left audio out is summed and supplied to that regulator and also to LED vu meter. Must be giving the supply a little kick at higher volumes.
Feeds back speaker voltages via R327, 328 and output stage current (around 12A peak) via (left chnl.) R211, 213, Q113, 115, 301. These are combined in IC301. If I got the polarity inversions right, this shows up as a negative feedback to the Triac ckt. The speaker voltages seem to be pretty much a linear feedback, and the output stage current more of a hard current limit function, both with some time delay/averaging from the IC301 outputs.
Thanks !
You are quicker than me. I only just now found "MP101" which carries speaker current signal over to upper left corner...
Now i see what they mean by "multiplex" power supply -
that mess surrounding Q127, Q129, Q133 and Q137...
too many frills for my taste.
I'll keep plugging.
Have you figured out what advances firing during high power?
That negative speaker current feedback might be for speaker damping, but I'm not sure.
I think you pretty much nailed it in your post #143. If any DC supply voltage drops below nominal, the Triac phase angle is advanced. fires earlier.
Here's my take on it.
Left Chnl:
Q127, 129 Audio Output stage.
Supplied by:
idle D127 (30V supply);
at higher audio input levels Q131, 133, D125 (60V supply);
at speaker >+52VPK Q139, 143, 145 (then thru Q131, 133) (100V supply)
Q113 is current limit for output stage with fast clamping at 25A peak.
BTW:
The 100V supply is used only above 320WPK into an 8 Ohm speaker. (WOW!)
Except for C101 0.47uF at the RCA input jacks, the whole rest of the amplifier is DC coupled. (Need a decent servo amp for something?)
This thread reminds me of browsing TV repair anecdotes and tricks in Popular Electronics circa 1963, when I was 12 years old. The shop lingo was exotic. "Back porch", "color burst", "horizontal sweep", "video amplifier", "AGC" and the like all stimulated my imagination, as tales of pirates or race cars might have for un-geeky boys.
Well Ralph, I will only speak for myself, but I think I may not be the only one on this thread who was actually reading Popular Electronics in 1963. 1963 was a good year as I had a 1963 Chevy Super Sport convertible.
Rear three-quarter view of a red 1963 Chevrolet Impala convertible with the top down, showing its triple round taillights and chrome trim.
Mine was a different color. In 1963 Tom Wolf published in Esquire magazine something about a "Kandy-Kolored Trangerine-Flaked Streamlined Baby so I just had to paint the car that color.
The sixties in America was a special time and I have fond memories of those times.
Cheers,
Billy
