How to unscrew a nut from a generator
  • Thread starter Thread starter ual8658
    Generator
To unscrew a nut from a generator's rotating shaft, it's essential to ensure the correct thread direction, as it may be left-handed. Users suggest methods to immobilize the shaft, such as using a chain wrench or a block of wood to prevent rotation while applying torque to the nut. An impact wrench can be helpful, but caution is advised to avoid over-tightening when reassembling. The discussion emphasizes the importance of proper technique to avoid damaging components during the process. Overall, using a combination of tools and techniques can effectively remove the stubborn nut.
ual8658
I was hoping with the academics and engineers present on this forum, somebody could enlighten me. I have a generator with a nut on the end of the rotating shaft. However, if I try to unscrew it, the entire shaft rotates with it, and I can't hold the shaft still because it seems the nut's torque is too great. Is there a way to get it off?
Can you post some pictures?
Likes Nidum
Are you sure of the handedness of the threads? i.e., you spun the shaft with a fingernail the thread groove. I have sometimes wasted a few minutes trying to unscrew a nut - the wrong way.
Likes 1oldman2 and berkeman
http://imgur.com/t0CCxVG
This is a stock generator direct from a seller. We have not yet modified/touched it.
What Jim refers to is its not uncommon for the threads securing the nut to be threaded in the opposite direction of shaft rotation.
The shaft will turn both ways.
This would be normal however you need to define the direction it turns while its generating power.
It is in the counter clockwise direction.
Likes 1oldman2
At this point I usually search for online service manuals, there is undoubtedly a method for locking the shaft regardless of which way the threads turn.
Likes ual8658
Presumably the sprocket is splined or keyed to the shaft, have you clamped the sprocket to hold the shaft? Scrap wood will prevent tooth damage.
Likes gjonesy, CWatters and Nidum
Get a short length of roller chain that fits, then drop it over the sprocket. Google images 'chain pipe vice'.
Hold the sprocket by the chain in a vice, or with a Stilson pipe wrench, the chain will protect the sprocket teeth.
Then undo the nut by turning it forwards and backwards with ever increasing torque.
At some point the nut will turn easily and come off the threaded shaft. You will then know if it is LH or RH threaded.
If it is a tight fit you may then need to use a puller to remove the sprocket from the keyed shaft.
Likes gjonesy, anorlunda and jim hardy
I like the chain idea - how practical !
Or get a 1/2 inch drive socket that fits the nut
ask the guys at your local tire shop(or a handyman neighbor) if they''ll spin it off with their "impact wrench"First though, it would be prudent to call whoever sold you the generator and ask whether it's left or right handed threads.
Likes ual8658 and 1oldman2
You may need to use some impact. Like a box end wrench on the nut and a hammer. And note that if the nut and shaft are threaded to "tighten" in normal use then the nut would come loose turning it the same direction as normal rotation. I'd go with right hand as a first guess unless you can see some threads.
So to ensure I'm doing this right, I'm basically trying to hold the shaft still with the chain via a pipe wrench?
Thanks! I will definitely try this.
Yes.
Your picture shows a nut with a rounded outer surface. That looks like a “nylock” nut which will almost certainly be a right hand thread.
I am a bush engineer when I do not have all the tools I need. To do this job I would simply rest the sprocket on a block of wood with the motor just off the floor or bench. Put a ring spanner on the nut, then hit the end of the ring spanner with another block of wood. The inertia of the rotor will prevent rotation during the short initial impact. The block of wood that the sprocket rests on will prevent damage to the motor bearings.
"Ring spanner" is a proper British term, for Americans it's "box end wrench".
Don't expect it to budge on first blow.
Doing it up again might be harder.
My thought, too. Are you sure you need to remove the nut ? Are you changing the sprocket? Or has removing the nut become a challenge in itself?
If it must come off, a chain around the sprocket and use of an impact wrench would probably be the safest approach.
Check tool sales . I found an el-cheapo electric impact wrench ½"drive for $40 at one of the import discount store sales. It's just right for little jobs like this and you don't have to have an air compressor. Paid for itself on first use.
There is a special pipe wrench called a (chain wrench)
http://www.bing.com/images/search?q...54ddcdb848c8e9b6b76dd1c2721daa31o0&ajaxhist=0
You have to cut a small block of wood to put on the jaw but it will hold it so you can remove the nut. baluncore and Billy_joule were on the right track. I have had to deal with these before and they are a pain in the butt!
Note: if the sprocket has a keyway keeper (shear pin) you WILL probably dent it and need to replaced it unless you have an impact gun.
You should not have to buy an impact wrench for a job like that. I have several impact wrenches, but I would not use one on that nut. You will have no idea how tight it was previously if you remove it with an impact wrench. You need to put it back on with a similar torque. You need to do it with feeling, that is not a job for an impact wrench set up for regular work.
If you are in the USA then get a box end wrench and a couple of blocks of wood. Anywhere else on Earth, just substitute a ring spanner for the box end wrench. I would have had the nut off in less than 30 seconds.
Have you removed it yet ?
If not, what is stopping you doing it now ?
Those chain wrenches use a special stronger structure chain, unlike roller chain, that does not have the rollers to hold the sprocket teeth. It is not applicable to holding a sprocket without damaging the sprocket tips or spreading the chain.
I have done it more than once it will work, Never damaged a chain or sprocket, that's why you add the block of wood to the jaw. I worked on a crew in a factory that used chain drive electric motors for 3 years. And it works like a charm. The only thing we ever damaged was the shear pins and those were made to "give" before the chain or sprocket teeth in case the motor gets in a bind. We never completely sheared a pin, some times wed dent them most times we never had a problem.
I have to see the assembly, but why are you not able to hold the sheave still? Can you post an image? You may find good advice at www.practicalmachinist.com. GL.
Thank you all. I'm still confused as to what I'm supposed to do with the wood?
Where you must grip or support an ugly shaped steel component, a block of wood will not damage the steel component.
The wood will conform to the component and so spread the load. The wooden block can be sacrificed to save the component.
Place the block of wood anywhere that will prevent the shaft from turning, such as in the gear teeth on the shaft.
How would I do that? Do I ahve to cut a piece of wood so it will rest on the table and also in the gear teeth?
You need more experience dismantling old machines like lawn mowers, bicycles and cars.
There is no hope. All is lost. You are in a situation from which you cannot recover, unless you take the first step.
If you are unable to take that first step, then you should take the motor to a friendly mechanic who is good at fixing things.
Steel vice jaws would damage the sprocket so use scrap wood as sacrificial soft jaws:
No need for the magnets, you'll be throwing them out after using them once, the sprocket will crush into the wood and you'll get a good grip.
