Applying Poisson Equation for Electrostatic Potential in a Spherical Shell
To find the electrostatic potential inside a spherical shell with a small patch at constant potential V_0, the Poisson equation must be applied with appropriate boundary conditions reflecting the spherical symmetry. The problem can be approached using spherical coordinates, where the boundary conditions are crucial for solving the partial differential equation. The size of the patch relative to the sphere's radius may influence the solution, and methods such as Legendre polynomials or numerical techniques like relaxation methods can be employed. Reference materials like "Numerical Recipes in C" may provide additional insights into these numerical approaches. Ultimately, the solution hinges on accurately defining the boundary conditions and applying the Poisson equation accordingly.
KFC
In many book I read, problems for electrostatic potential always lead to solving Poisson equation. I saw a problem about a spherical shell carrying some amount of charges uniformly on the surface with density \rho, and then someone put a small patch on the sphere. The patch is then made a constant potential V_0 on it and everywhere else on the shell has zero potential. I would like to find the potential everywhere inside the spherical shell. In this case, how can I apply Poisson equation to do that?
The Poisson equation always holds, and the given configuration is encoded in the boundary conditions. To solve a PDE you always have to give the boundary conditions. So in this particular problem, due to the spherical symmetry its best to operate in spherical coordinates, and then describe the given boundary conditions.
Do you mean the size of the patch compared to te radius of the sphere is to be known?
If in spherical co"ordinates north pole could be an answer. Would the use of Legendre polynomals work?
It could be done using numerical methods, for example by relaxation methods. I'm pretty sure the book "Numerical Recipes in C" covers this, if you want to look up the details.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
