Selling Papayas
- 4
I apologize in advance if any formatting is weird; this is my first time posting. If I am breaking any rules with the formatting or if I am not providing enough detail or if I am in the wrong sub-forum, please let me know.
1. Homework Statement
Using Euler's formula : ejx = cos(x) + jsin(x) and the exponential representations of sin & cos, which are derived from Euler's formula:
##\displaystyle \sin(x)=\frac {e^{jx} - e^{-jx}} {2j}##
##\displaystyle \cos(x)=\frac {e^{jx} + e^{-jx}} {2}##
write the following in terms of sin & cos:
I posted the ones given in the problem in part 1, and the only other one I used is ##j = e^{j \frac {π} {2}}##
This is probably obvious, but my classes use j instead of i to represent the imaginary number.
So for part 1, I think I solved it counter-intuitively (Wolfram Alpha says my solution is equivalent but its extremely long and I still feel as if I'm missing some key conversion)
I converted the j's into ##e^j\frac{π}{2}##, multiplied the exponentials together (adding the exponents in each term) and ended up with the following:
For part 2, I am getting stumped pretty quickly. I've tried to apply the methods I used in part 1 to solve this, but can't seem to pull out the k and the π from the denominator.
What I've done so far:
- ##\displaystyle je^{j \frac {π} {4}t} - je^{-j \frac {π} {4}t} + 2e^{j \frac {5π} {4}t} + 2e^{-j \frac {5π} {4}t}##
- ##\displaystyle \frac {3} {4jkπ} (1-e^{-jkπ})^2##
##[\cos(\frac {π} {2} + \frac {π} {4}t) + j\sin(\frac {π} {2} + \frac {π} {4}t)] - [\cos(\frac {π} {2} - \frac {π} {4}t) + j\sin(\frac {π} {2} - \frac {π} {4}t)] + 2[\cos(\frac {5π} {4}t) + j\sin(\frac {5π} {4}t)] + 2[\cos(\frac {-5π} {4}t) + j\sin(\frac {-5π} {4}t)]##
As you can see, it's a lot, but I am confident I at least have a right solution.For part 2, I am getting stumped pretty quickly. I've tried to apply the methods I used in part 1 to solve this, but can't seem to pull out the k and the π from the denominator.
##\displaystyle= \frac {3} {4jkπ} (1-e^{-jkπ})(1-e^{-jkπ})##
##\displaystyle= \frac {3} {4jkπ} (1 - 2e^{-jkπ} + e^{-2jkπ})##
##\displaystyle= \frac {3} {4jkπ} - \frac {3e^{-jkπ}} {2jkπ} + \frac{3e^{-2jkπ}} {4jkπ}##
