How work is done on an ideal gas?
In a fixed volume gas system, adding more gas molecules increases both pressure and temperature due to the work done in pushing the new molecules against existing pressure. This work raises the average kinetic energy of the gas molecules, resulting in a temperature increase. The elastic collisions among molecules ensure that the kinetic energy remains unchanged, but the addition of molecules inherently alters the system's energy. Therefore, it is impossible to add molecules to an ideal gas at constant volume without affecting its energy and temperature. The concept of non-zero chemical potential plays a crucial role in understanding these changes.
jerry0696
Consider a system of volume V and pressure P ,if i add molecules of gases in the system while keeping its volume constant and not providing any energy nor absorbing energy from the system ,its pressure will increase and so does its temperature
Why does the temperature increase?
More molecules means more collision but the collisions are perfrctly elastic so it doesn't make any difference isn't it?
And for the temperature to increase work has to be done on the gas but how work is done on a fixed volume of gas?
To add the molecules of gas, you had to push them into the container against the pressure of the gas already there. That pushing did work on them.
The temperature increase comes from increasing the average kinetic energy of the gas molecules as you pushed on them. The elastic nature of the collisions between the molecules just means that the kinetic energy of the molecules, both what they started with and what you added by pushing more molecules in, remains as kinectic energy.
You can't add molecules to the ideal gas keeping volume constant without changing its energy. It has a non-zero chemical potential.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
