How would Fg vs. r look on a graphical diagram?Fg on y-axis, r on
  • Context: Undergrad
  • Thread starter Thread starter saan100
The discussion centers on the graphical representation of gravitational force (Fg) versus radius (r), specifically with Fg on the y-axis and r on the x-axis. Participants conclude that the relationship between Fg and r is inversely proportional to the square of the radius, as expressed by the equation Fg = G*m1*m2/r^2. Additionally, the required orbital velocity for a cannonball fired from the height of Mount Everest is derived using the formula v = sqrt(GM/r), where G is the gravitational constant, M is the mass of the Earth, and r is the radius of the Earth plus the height of Everest.
  • Understanding of gravitational force equations, specifically Fg = G*m1*m2/r^2
  • Knowledge of orbital mechanics and velocity calculations, particularly v = sqrt(GM/r)
  • Familiarity with the concept of inverse-square relationships in physics
  • Basic understanding of the Earth's radius and height measurements, such as the height of Mount Everest
  • Research the derivation and applications of the gravitational force equation Fg = G*m1*m2/r^2
  • Study the concept of orbital velocity and its calculation using v = sqrt(GM/r)
  • Explore the implications of inverse-square laws in gravitational physics
  • Investigate the effects of altitude on gravitational force and orbital mechanics
Students studying physics, educators teaching gravitational concepts, and anyone interested in orbital mechanics and the effects of altitude on gravitational force.
saan100
how would Fg vs. r look on a graphical diagram?
Fg on y-axis, r on x-axis (from 1re to 6re)
re (radius of the Earth)
If a cannon ball is fired from the top of Everest parallel to the Earth's surface fast enough (ignoring air resistance and assuming that it doesn't bump into anything), it will "orbit" the Earth and hit the back of the cannon that it was fired from. Find the speed required to do this.
As this is homework, you'll need to show an attempt first.
The relationship for the first part is what? Linear? Squared? Cubic? Inverse-Square?
The second part, what equations do you know?
for the first part, it would linear .
for the second part, i would use v=2pi*r divided by T
Really? What's the equation for gravitational force?
I'm going to refer you here: http://en.wikipedia.org/wiki/Orbital_speed
You'd be better off using v = sqrt(GM/r) as you know all the numbers for that quite easily.
Where v = velocity, G = gravitational constant, M = mass of earth, r = radius of Earth plus height of everest.
If you don't know the speed, you won't know T from your above equation.
- the equation for Fg = G*m1*m2/r^2
-for second part, I'm confused over the formula you provided. Would you kindly explain it?
Ok, so what does that tell you about the Fg and r relationship?
Have a read through the link I provided, it's really short.
v = \sqrt {\frac {GM}r}
If you plug in the numbers as per my previous post, you will get the required orbital velocity for the height of everest. In other words, the speed you need the canon ball to travel at. That's all there is to it.
The relationship - The greater the radius, the lesser the gravitation force
Of course, but what does the equation tell you?
Gravitational force decreases...
a) linearly to radius.
b) proportional to the square of the radius.
c) proportional to the cube of the radius.
d) inversely proportional to the square of the radius.
Look at it a bit simpler, the relationship is g = a/r2.
Where a = Gm1m2
- for the second part question, in the equation r = re + h , how do u get the height of the everest
No, ok I'll give it to you. Gravity is inversely proportional to the square of the radius.
Google.
thanks for the help !
Do you understand the first bit regarding the relationship though? Could you explain it with reference to the equation?
  • · Replies 42 ·
19K
  • · Replies 39 ·
