pairofstrings said:
In my recent attempt to find
area of rectangle, I drew a figure of rectangle 6 units wide and 3 units tall.
In my attempt I assumed that I am traveling by foot. Each unit is one step. I travel 3 steps vertically and 1 step horizontally while I cover the area.
You are not "covering the area". You are following what is essentially a one-dimensional path (length) through a two-dimensional region (area).
pairofstrings said:
I took 27 steps to move from initial point to final point. If I reached the end point this way it means that I have covered the entire area. True?
No, false. Clearly the lines you drew do not cover each point in each of the rectangles. You are trying to measure something that is two dimensional using a one-dimensional measure. There is an essential difference between one-D measures such as meter (m) and two-D measures such as square meters (m
2).
pairofstrings said:
I believe, the following is a false statement.
27 steps = 6 x 3 => 27 steps = 18 units (false).
Yes, this is false. You are completely ignoring the units. Your steps are linear (one-D), and the area is in units of some two-D measure such as square inches or square meters.
pairofstrings said:
6 x 3 represents the formula of area of rectangle by proven method.
I later decided to convert my 27 steps into something which fits my equation.
So, 27 steps = z = 18 units.
As mentioned above, you're comparing apples and oranges. As already mentioned, you are ignoring the units of area.
pairofstrings said:
What could be z? My thought is that if z could give me the exact value of area of given rectangle (which is 18 units) then I somehow need to reduce 27 by some amount to make it 18 units. What could be that amount and how do I know how to calculate?
Does all of this make sense or my logic is flawed?
If flawed then how to calculate area by traveling by foot!? If traveling by foot logic to find area of rectangle is flawed, please explain why.
When you measure something, you need to use a measuring device that is appropriate to the thing you're measuring. You wouldn't use a ruler to measure the weight of a rock, nor would you use a stopwatch to determine the color of an apple.
If you want to measure a length, you can use a ruler. If you want to measure an area, you need to use something that is two-dimensional. If you want to measure the volume of, say, a box, you would use some three-dimensional object to see how many of them would fit into the box.
