Humming Capacitor: Causes and Solutions
  • Thread starter Thread starter Tree Penguin
    Capacitor
A humming sound in speakers is often caused by a 60 Hz hum linked to faulty capacitors in the amplifier. This issue may arise from aging components that vibrate and produce noise. To diagnose the problem, test the speakers on a different system to see if the hum persists. Additionally, swapping in known good speakers can help confirm whether the issue lies with the amplifier or the speakers themselves. Addressing bad capacitors is essential for restoring sound quality.
Tree Penguin
Hi, what can cause a capacitor to hum?
My active speakers are producing a lot of hiss (tweeter) / low humming (bass speaker) and the cause seems to be a capacitor as it vibrates a little and makes some noise doing it. Is it because of ageing?
Thanks.
what you are hearing is 60 hz hum probably due to bad capacitors in your amp.
proof: put your speakers on another system and see if it goes away. double check by putting proven speakers on your system.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
