Hydraulic - flow inside a pipe, how to know the direction?
6 replies · 2K views · last reply
amrfd
hydraulic -- flow inside a pipe, how to know the direction?
if you have a flow inside a pipe, how to know the direction?
welcome to pf!
hi amrfd! welcome to pf! :smile:
google "non invasive flow monitor" :wink:
(i think they all use the doppler effect)​
thank you for your reply but what do you mean with doppler effect?
they bounce ultrasound off the water, and measure the change in frequency of the sound …
do that google search, and you'll find out how :wink:​
thank you very much
if i don't have this device,is there another way to know the direction of flow?
i doubt there's anything cheaper :redface:
(that doesn't involve cutting a hole in the pipe)
Are you asking from a practical perspective or just for information?
There should be a drop in pressure the further from the source you go (as long as there is flow).
Could also cause local turbulence in the line with a small "wall" and put sensors behind and in front of the wall. The wall is causing the turbulence - would see pressure differential as long as there is flow. Think about an airplane wing and pressure differential top to bottom - only sideways :)
(I'm no expert - but this is a fun thought experiment!)
