Explaining the Hydrogen Atom Wave Function Paradox
albertsmith
The hydrogen atom 1s wave function is a maximum at r = 0. But the 1s radial probability density, peaks at r = Bohr radius and is zero at r = 0. can someone explain this paradox?
It looks like you don't have the entire wave function. It seems as if you're looking only at the radial portion of the wave function "R(r)". You can look at the "effective radial wave function" by multiplying by r^2. This acts just the the r^2 necessary in the spherical coordinate integral. Someone else can better explain why you would do this.
First note that the wave function gives you (by way of |\psi|^2) the volume probability density: the probability per unit volume of finding the particle at or near a given point.
To simplify the discussion, suppose we have a uniform volume probability density \rho.
Now ask the question, what is the probability that the particle is located a distance r from some point (e.g. the center of a sphere)? Loosely speaking, if r is large, there are more points at that distance; and if r is small, there are fewer points at that distance. So the total probability of being at some point at distance r increases as r increases, and decreases as r decreases.
To make this more precise, consider the probability that the particle is located in a thin spherical shell of thickness dr and radius r. For a uniform volume probability density, the probability of being in the shell is approximately (thickness of shell)(area of shell)(probability density) = 4 \pi r^2 dr \rho. Factoring out the thickness of the shell we have the radial probability density 4 \pi r^2 \rho. Even though the particle has the same chance of being located at or near the center, as at any other point, it has a smaller probability of having a smaller r than a larger r.
The hydrogen 1s wave function and volume probability density are not uniform, but the same idea applies, when we switch from volume probability density to radial probability density.
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
