What is the Equation of the Locus of Points in the Hyperbola or Ellipse Problem?
  • Thread starter Thread starter Appleton
    Ellipse Hyperbola
The discussion revolves around finding the equation of a locus of points defined by their distances from the y-axis and a specific point (4,0). The initial calculations suggest the locus is an ellipse, but the textbook claims it is a hyperbola. Participants confirm that the calculations are correct and that the locus is indeed bounded, indicating it cannot be a hyperbola. The confusion arises from the wording of the problem, which would have indicated a hyperbola if the distance condition were reversed. Ultimately, the conclusion is that the book's classification is incorrect.
Appleton
1. Homework Statement
The following question is posed within a section of my A level maths book titled "The Hyperbola"
A set of points is such that each point is three times as far from the y-axis as it is from the point (4,0). Find the equation of the locus of P and sketch the locus
2. Homework Equations 3. The Attempt at a Solution
If P is a point (x,y) on the locus, and N is the intersection on the y-axis of the line through P, parallel to the x axis, and S is the point (4,0) then
<br /> PN = 3PS\\<br /> <br /> PN^2 = 9PS^2\\<br /> x^2 = 9((x-4)^2+y^2)\\<br /> \frac{8}{9}x^2+y^2-8x+16=0\\<br />
Which I believe is an elipse, but my book indicates that it is a hyperbola with it's answer of
<br /> 8x^2-y^2+8x-16=0<br />
Is my book wrong?
Is my book wrong?
Yes, YOU are right. You can even plot the curve in some package such as Maple to see what is happening.
You can even argue intuitively that the curve must be bounded in the plane, because if you could take ##x \to \infty ## very large (and ##y## moderate) on the curve you would have have (approximately) ##x \approx 3 (x-4)##, so ##x \approx 6##, contradicting the condition that ##x \to \infty## is very large.
Thanks, it's encouraging to know that writers of maths books fall prey to the same kind of mistakes that I do, if a little less frequently.
Can happen. The hyperbola they give as result is the solution of the exercise "A set of points is such that each point is three times as far from the y axis point (4,0) as it is from the point (4,0) y axis."
It would have been a hyperbola if it had said "... is 3 times as far from the point (4,0) as from the y axis".
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
