Hyperbolic path in Minkowski space
The discussion centers on the path of a constantly accelerating particle in Minkowski space, expressed by the equation x=c√(c²/a'²+t²). It highlights that omitting the c²/a'² term simplifies the equation to x=ct, which aligns with the distance traveled by a photon. The conversation explores the counterintuitive result that slower acceleration allows for greater distance traveled, leading to confusion about the interpretation of the equations. The participants clarify their calculations and derive alternative forms of the distance equation, emphasizing the relationship between proper acceleration and distance traveled. Overall, the discussion reveals the complexities of relativistic motion and the importance of precise calculations in understanding these concepts.
luitzen
The path described by a constantly accelerating particle is given by:
x=c\sqrt{c^2/a'^2+t^2}
where a prime denotes an observer traveling with the particle and a letter without a prime a resting observer.
If we leave the c^2/a'^2 out it reduces to x=ct, which makes sense. The distance traveled by a photon is simply it's speed times the travel time. If we think of a constantly accelerating particle, a particle which would first need to accelerate to a speed c (or at least close to it), we would expect that it would travel a shorter distance in the same amount of time, since it would first need to accelerate and hence travel at a smaller average speed. However, when you look at the equation above, you can see the travel time gets a little bonus, c^2/a'^2:
x=c\left[t+f\left(c^2/a'^2\right)\right]
According to the equation, the slower one accelerates, the larger distance one will be able to travel. To me that does not make any sense at all, so I wondered whether I made any mistakes and decided to verify the answer on the internet. However, without blinking an eye, every single source I find online gives me the same answer.
So where do I go wrong in all this?
Sources:
http://en.wikipedia.org/wiki/Hyperbolic_motion_(relativity )
http://www.physik.uni-leipzig.de/~schiller/ed10/Uniform relativistic acceleration.pdf
Careful: where is the particle at t = 0?
x\left(t=0\right)=c^2/a'
So I should define a new axis x'' then?
x''=x-c^2/a'=c\sqrt{c^2/a'^2+t^2}-c^2/a'=c\left(\sqrt{c^2/a'^2+t^2}-c/a'\right)
If a' goes to infinity:
x''=ct
If a' goes to zero:
x''=c\left(\sqrt{c^2/a'^2}-c/a'\right)=0
Let's say a'=0.5c/yr, t=5 yr:
x''=c\left(\sqrt{4+25}-2\right)=2.39ly
t=infinity:
x''=c\left(\sqrt{c^2/a'^2+t^2}-c/a'\right)=c\left(\sqrt{t^2}-c/a'\right)=c\left(t-c/a'\right)=ct
This makes all sense to me. Thank you.
This source http://math.ucr.edu/home/baez/physics/Relativity/SR/rocket.html gives the distance traveled as:
d =\frac{c^2}{a}\left(\sqrt{1+\left(\frac{at}{c}\right)^2}-1\right)
d in this case increases with increasing proper acceleration a.
For your example in your second post, when a=0.5c/yr, t=5 yr, d=3.385 lyr.
It's the same, but I made a calculation error. I did \sqrt{25+4}-3 instead of \sqrt{25+4}-2
I prefer my version though, since it's in the form of c times a time.
In my formula it's also much more obvious that d increases with increasing a'.
Here is how to get from the equation given in the Baez link I posted, to the equations in your links.
Starting with:
which can be rewritten as:
d =\sqrt{\frac{c^4}{a^2}+c^2t^2}-\frac{c^2}{a}
where d=0 when time t=0.
In the Rindler coordinate system (X,T), the distance from the origin is c^2/a at time T=0 and the proper acceleration (α) of a given particle is proportional to c^2/X also at T=0. This means that the above equation can be written in terms of X as:
X = d+\frac{c^2}{\alpha} = \sqrt{\frac{c^4}{\alpha^2}+c^2T^2}
which is essentially your equation at the start of this thread. Note that α is constrained to be the value of c^2/X at time T=0.
P.S. I see I missed your post while posting this and that you had already figured this out. I was thrown by the fact you got a different result but that was just a numerical error.
If we rearrange that equation in terms of the co-ordinate time we get this:
t =\sqrt{\left(\frac{2d}{a}\right)+\left(\frac{d}{c}\right)^2}
...so the co-ordinate time can be thought of as having two time components - the Newtonian time to travel a displacement d at a constant acceleration a, and the light travel time. I'm not sure if that makes sense, but that's how it looks to me from the equations.
Thanks, that makes total sense.
  • · Replies 36 ·
  • · Replies 20 ·
  • · Replies 34 ·
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 17 ·
