I am going to lose it I need a hint
  • Thread starter Thread starter Roger Wilco
10 replies · 3K views
Roger Wilco
just to get me started! This is killing me...
I need to derive the formula for an work done W of an adiabatic expansion of an ideal gas: [tex]W=\frac{1}{1-\gamma}[p_2V_2-p_1V_1][/tex]
Using the fact that [tex]p_1V_1^{\gamma}=p_2V_2^{\gamma}=constant[/tex]
thanks
RW
Roger Wilco said:
I know that [tex]W=\int pdV[/tex] also...
Here's a hint.
Rewrite: [tex]pV^{\gamma}=C[/tex]
As [tex]p=C/V^{\gamma}[/tex]
Okay from now on Will use n in place of gamma for simplicity.
So now if I have [tex]W=c\int\ V^{-n}dV[/tex]
[tex]\Rightarrow W=c\frac{V^{-n+1}}{-n+1}[/tex]...
Now I am stuck again. ...
Redo that integration more carefully. (Check by taking the derivative of your answer.)
Gotcha...now I am having trouble putting that in terms of p1 and p2...I now have it in terms of c...and I still have 1-n up in th exponent...do I need a natural log somewhere?
Thank you
RW
Doc Al said:
You can replace c with what it equals.
But which do I use...I know [tex]p_1V_1^n=p_2V_2^n[/tex]
oh..wait... how about I distibute c first and then replace it...it's clear now.
Thanks Doc!
You're the best!
RW
So to actually evaluate this expression when I am given pressure in atms and volume in cubic centimeters do i need to convert these units into SI.
I see that the coefficient of 1/(1-n) is dimensionless. And I had assumed that since p1v1-p2v2 had the SAME dimensions it would be okay to NOT convert...
i think I see my error though...I need Joules when all is said and done. I may have answered my own question.
RW
