NaughtyBear
- 17
- 1
These two symbols lose me. I am making something for a project and cannot figure the two circled in red out. This circuit is for a disposable camera.
I doubt the circuit will work without them.NaughtyBear said:Oh thanks! :D So Because I do not need those, I can tie L1 into the circuit as opposed to FL1?
? what is it supposed to do ?NaughtyBear said:Here is the thought for a project.
Do you understand charge rate is determined by current available through Q1 T1, which isn't a lot ?NaughtyBear said:I need the capacitors to be charged and discharge very quickly.
I can't read the print. If you used nine of those 120uf 300volt caps, you now have 80 uf at 900 volts.NaughtyBear said:But I am not 100% sure I have built the capacitor bank correctly.
NaughtyBear said:I was following a tutorial, http://www.instructables.com/id/The-0-Coil-Gun/ and decided that I wanted to try to make it move faster. The author says that it takes approx. 10 mins or so to charge. So I assumed you either need more amps or more capacitors. However I am still learning. Thus, before I decided to start putting things together and trying, I thought it best to take it somewhere to share my ideas.
