I evaluating this vector product identity
The discussion focuses on evaluating the vector product identity expressed as Del X (A X B) = (B*DEL)A - (A*DEL)B + A(DEL*B) - B(DEL*A). The author struggles with the evaluation due to confusion over the order of operations and the commutativity of the dot product. Two methods for proving the identity are suggested: using tensor notation, which is independent of coordinate systems, and expanding both sides in a rectangular coordinate system to verify component equality. The latter method, while tedious, is effective for demonstrating the identity's validity.
  • Understanding of vector calculus and vector identities
  • Familiarity with tensor notation and its application
  • Knowledge of rectangular coordinate systems in vector analysis
  • Proficiency in manipulating dot products and cross products
  • Study tensor notation and its relevance in vector calculus
  • Practice expanding vector terms in rectangular coordinate systems
  • Explore additional vector identities and their proofs
  • Learn about the properties of dot and cross products in vector analysis
Students and professionals in mathematics, physics, and engineering who are working with vector calculus and need to understand vector identities and their proofs.
sunnyslumber
The problem is written as:
Del X (A X B) = (B*DEL)A- (A*DEL)B +A(DEL*B) -B(DEL * A)
where * = dot. I don't know how to evaluate this because if the author meant for the standard mathematical order of operations to apply it makes since they wouldn't have worried about the sequence of the statements (since the dot product iscommutative). Every way I'm working it its coming up wrong.
Can anyone help? I just need to know how to evaluate the expression.
I assume that what you've been ask to do is to prove this vector identity, which is what it is. There are at least two ways to do this, perhaps three. The simplest way, and one which is independent of any particular coordinate system, is to use tensor notation ( a vector is a tensor of rank 1), but I'm guessing you are not familiar with tensors.
Another much more tedious method is to prove its true in the rectangular coordinate system; this doesn't make it necessarily true for vectors in general, but it may suffice for your purposes. Basically what your do is start by expanding both sides. Then sum all the x components on the right side, and you'll see that the resulting x components are the same on both sides. Then wave your arms wildly and say that by the same process, the y and z components are equal (which they are), or continue the tedium if you must.
All this assumes you know how to expand each of the five vector terms.
  • · Replies 17 ·
25K
  • · Replies 33 ·
17K
