How do you determine which denominators to multiply in integrating fractions?
In summary, when solving equations with multiple denominators, it is necessary to multiply both sides of the equation by the entire denominator to ensure equality. This allows for the simplification and solving of the equation for variables such as A, B, C, etc. However, in some cases, certain denominators may be excluded from the multiplication process due to their repeated nature.
Juche
36
We just started this and I mostly understand it except when it comes to using A, B, C, etc substitution. What I mean is this, here is an exampe.
(6x^2+x+1)/(x^2+1)(x-1) = (Ax+B)/(x^2+1) + (C)/(x-1)
You then multiply by denominators so you end up with (Ax+B)*(x-1) + (C)*(x^2+1). You multiply and factor and end up with (A+C)x + (-A+B)x + (-B+C). Then you solve the equations for A B and C since (A+C)=6, (-A+B)=1 and (-B+C)=1.
But how do you know which denominators to multiply the numerators by? In some problems you end up with 5 or 6 different denominators, and I do not know which ones to multiply the denominators by. In some problems (unlike the one above) it is broken down into 5 or 6 different integrals instead of 2 and if I don't know which ones to multiply out I cannot solve for A, B, C, etc.
You multiply through by the entire denominator. Remember that it's an equation, so the two sides must be equal. In your example,
[tex]\frac{(6x^2+x+1)}{(x^2+1)(x-1)} = \frac{(Ax+B)}{(x^2+1)} + \frac{C}{(x-1)} [/tex]
you'd multiply both sides by (x2 + 1)(x-1), to give you
6x2 + x + 1 = (Ax + B)(x - 1) + C(x2 + 1),
and you would then expand out the right side and match coefficients of powers of x, as you did before (that's where those equtions come from!) or you could substitute in some choice values of x to easily solve for some variables.
For instance, if you let x = 1, you get the equation
8 = (A + B)*(0) + 2C
8 = 2C
C = 4
You can't pull this trick for all of the values, but it's good to get a few easy ones.
--J
With all:
[tex] \frac{A}{Bx+C}+\frac{D}{Ex+F}+\frac{G}{Hx+I}+\frac{J}{Kx+L}+...[/tex]
In this simple example,you have to multiply A with all the other monoms,except "Bx+C"...
Daniel.
My calculus professor had this weird thing he does that even when I asked him about it he didn't explain it in a way that I understood it. It was
Ax+B/(x^2+1) + Cx+D/(x^2+1)^2 + Ex+F/(x^2+2x-2) + G/(x+1) + H/(x+1)^2 + I/(x-2)
he wouldn't just multiply Ax+B by all of them, he may exclude (as an example) the denominator from G and I have no idea what he was doing or why when he did that.
For the record, can I just multiply out by all the denominators and get the right answers?
Ooops,you're right,my bad.Yes,multiplication only with the prime polynomials.Of course,the repeated ones,are not multiplicated twice...
Daniel.
What are the 'repeated ones' and what constitutes a 'repeated one'
This:
[tex] \frac{x+7}{(x-3)^2}=\frac{A}{x-3}+\frac{Bx+C}{(x-3)^{2}}[/tex]
You see,A is multiplied not with the other denominator...
Daniel.
1. What is the process for integrating fractions?
The process for integrating fractions involves finding the integral, or antiderivative, of a given fraction. This can be done using various integration techniques, such as the power rule, substitution, or integration by parts.
2. When do I need to integrate fractions?
Fractions often arise in mathematical equations and models. If you are trying to find the total area, volume, or quantity represented by a fraction, you will need to integrate it.
3. How do I know which integration technique to use for a given fraction?
Choosing the correct integration technique depends on the form of the fraction and the variables involved. Some fractions may require more than one integration technique to solve.
4. Can I simplify a fraction before integrating it?
Yes, simplifying a fraction can make it easier to integrate. However, be careful not to change the value of the fraction when simplifying.
5. What are the common mistakes to avoid when integrating fractions?
Some common mistakes to avoid when integrating fractions include forgetting to include the constant of integration, incorrectly applying integration rules, and not simplifying the fraction before integrating.
  • Calculus
  • Calculus
