I think this should be simple, but i
  • Thread starter Thread starter ethanmuncher
10 replies · 4K views
ethanmuncher
[SOLVED] i think this should be simple, but i need help!
this isn't really homework, but I'm having trouble figuring this problem out...
the problem says:
In this diagram, the red part has an area of 800 square centimetres.
What is the area of the green part, in square centimetres? Please round up to the nearest whole number.
i have no idea how to solve this, since the only information they give is that the pentagon is 800 square centimeters...
Well, I figured out that you could probably fold the green triangle into the pentagon, and make it 3 triangles, the 2 on the sides being congruent... but how do i figure out an area?
i like this problem, what book did you get it from?
i sort of have an idea but i don't think I'm the best person to help.
I think you're missing a piece of information on the triangles... as is, you don't have any information on how the edges not part of the pentagon act, except that the triangle is isosceles, so you can't actually get an answer
I really enjoyed this problem
The nicest I got the area to reduce to was:
[tex]\sqrt{\phi^2 - \frac{1}{4}} * \frac{1600}{\sqrt{25 + 10\sqrt{5}}}[/tex]Where [tex]\phi[/tex] is the golden ratio.
Can anyone confirm? Is this right?
I don't agree.
Assuming it is a regular pentagon, the side of a pentagon is in a golden relation with the side of the triangle.
Diffy said:
I don't agree.
I completely discounted that the diagram shows the triangles edges simply as extensions of the edges of the pentagon. Whoops
:confused: i really don't know what that means. I'm taking a 10th grade geometry class right now. if there was like a simple whole number you could use to solve, what would you, well estimate it to be?
From this page on the area of a pentagon
http://mathcentral.uregina.ca/QQ/database/QQ.09.04/susan1.html
I got that a pentagon with side length "2a" has area
Area_pentagon = 5 tan(54) a^2
where 54 means 54 degrees. From that page we can also get the angles in the triangle, and then I get
Area_triangle = tan(72) a^2
And so
Area_triangle / Area_pentagon = tan(72)/(5 tan(54))
And, amazingly, this works out to something very simple, namely [itex]1/\sqrt{5}=0.447[/itex]. The triangle looks to me to have an area between 1/3 and 1/2 the pentagon, so numerically this fits as well.
And so
That agrees with Diffy's result as well, which could have been simplified using phi=(sqrt(5)+1)/2.
Both answers work out to be around 357.7 This is good enough for me to confirm mine and Avodyne's answers are good.
thanks everyone! i rounded 357.7 to 358, and apparently it was the right answer. :)
