David lopez
- Messages
- 257
- Reaction score
- 3
i tried to build an induction coil. the input voltage is 12.1 volts. the output voltage is 16.5 millivolts maximum. so the voltage in the primary coil is 12.1 volts. the
voltage in the secondary coil is 16.5 millivolts maximum. the induction coil consist of a nail. thicker coils form the primary. thinner coil forms the secondary. the
primary consist of 213 turns. the secondary consist of 1,266 turns.
i connect the induction coil to a transistor rated at 1 amp. the collector pin is connected to a 6 ohm resistor. the 6 ohm resistor is connected to the induction coil. so current flows into the emitter pin and out the collector pin and then to the induction coil. if i alternately connect and disconnect the base, i get random values. sometimes as low as 200 microvolts. sometimes
as high as 16.5 millivolts.
if i connect the transistor to a 555 timer, i get 2.9 millivolts. if i use shorter pulses i get 100 microvolts. usually there are
gaps between the turns in the secondary. if i use a wider core will that get me a higher voltage?
if i eliminate the gaps between the turns in the
secondary, will that get me a higher voltage?
