I tried building an induction coil
In summary, the conversation discussed the building of an induction coil with an input voltage of 12.1 volts and an output voltage of 16.5 millivolts maximum. The primary coil consisted of a nail with 213 turns, while the secondary coil had 1,266 turns and was connected to a transistor rated at 1 amp. The collector pin of the transistor was connected to a 6 ohm resistor, which was then connected to the induction coil. Alternately connecting and disconnecting the base resulted in random output values ranging from 200 microvolts to 16.5 millivolts. The use of a 555 timer resulted in a consistent output of 2.9 millivolts with shorter pulses producing
David lopez
257
i tried to build an induction coil. the input voltage is 12.1 volts. the output voltage is 16.5 millivolts maximum. so the voltage in the primary coil is 12.1 volts. the
voltage in the secondary coil is 16.5 millivolts maximum. the induction coil consist of a nail. thicker coils form the primary. thinner coil forms the secondary. the
primary consist of 213 turns. the secondary consist of 1,266 turns.
i connect the induction coil to a transistor rated at 1 amp. the collector pin is connected to a 6 ohm resistor. the 6 ohm resistor is connected to the induction coil. so current flows into the emitter pin and out the collector pin and then to the induction coil. if i alternately connect and disconnect the base, i get random values. sometimes as low as 200 microvolts. sometimes
as high as 16.5 millivolts.
if i connect the transistor to a 555 timer, i get 2.9 millivolts. if i use shorter pulses i get 100 microvolts. usually there are
gaps between the turns in the secondary. if i use a wider core will that get me a higher voltage?
if i eliminate the gaps between the turns in the
secondary, will that get me a higher voltage?
We need a circuit diagram of your circuit, including the 555 timer and transistor.
Do you use an AC or DC range to measure the output voltage from your circuit ?
this is a schematic of the circuit
i posted a schematic. i am using dc current. now a answer my questions.
Take a look at your post. That schematic blur is unviewable.
Likes Vanadium 50, russ_watters and sysprog
No.
No.
If you want detailed assistance you will need to supply detailed information.
For instance:
  • A readable schematic, with values for all parts.
  • A description of the nail you are using. The one you are using may be small enough to fit on your finger nail, or maybe it is 8 inches long.
  • The approximate diameter of the nail.
  • The size of the wire you are using, both primary and secondary.
    (If you don't know, you can count the number of turns that will fit on one layer in 1 inch, or in 2cm.)
  • What power source you are using. (batteries, what size, how many? power supply, make, model, and rating)
  • What make and model meter you are using to measure the voltage and current.
That will give us a starting point. Otherwise we will have to ask these questions one at a time, making this a very long and tiresome thread.
Thanks!
Likes russ_watters, sysprog and Baluncore
i think this schematic is more readable.
the capacitor has 120 microfarads.
the first resistor has 3000 ohms. the second resistor has 1000 ohms. the nail is approximately 9.5 centimeters
long. the diameter of the nail is approximately 4 millimeters. i think the secondary uses 28 gauge wire. i think the
primary is roughly half a millimeter. not sure what gauge that is. i use 3 18650 lithium ion cells to provide roughly 12.2 volts. i think i am using a dt850l digital multimeter.
You show your input and output coils shorted to themselves. If that's how it's wired, it's no wonder it isn't working. You need to be pulling down on the bottom of the primary coil with your transistor's collector, and the top of the primary coil needs to be connected to the postive power supply. Then the bottom of the output coil needs to be grounded, and the top of the output coil needs to go through a diode to a storage capacitor.
Like this:
Likes sysprog
the bottom of the primary coil is connect to the transistor's collector. the top of the primary coil is connected to the
positive power supply. so current flows out of the transistor's collector, through the primary coil, and into the
positive power supply. the secondary coil is not connected to the power supply. the secondary is connect to the
multimeter, but not the power supply.
Can you please update your schematic to make it accurately reflect what you just said? Thanks.
Likes sysprog
i think this reflects what i said accurately.
Okay, that's better, thanks. But you should still take out the lines that appear to be shorting the primary and secondary coils just to be more clear and standard for drawing schematics.
If you don't use a rectifying diode in the output and want to measure it with an AC measurement, you need to be sure that the AC measuring device can keep up with the switching frequency. Maybe start with a diode there anyway just to make it so that you can measure the output with your DMM on DC input mode.
With those changes, what do you measure for your output DC voltage?
Likes sysprog
i have not made those changes i think. but should the secondary be connected to the power supply in any way?
No, it doesn't need to be. Your goal is to rectify the output pulses from the switching action of your transistor on the primary side.
Likes sysprog
is it possible the induction coil damaged the transistors? i use to read the full 12.2 volts from the collector. now i
read a fraction of a volt from the transitor. one time i measured the voltage at the collector it was .8 volts. then i
measured the voltage at the collector of a different transistor it was the full 12.2 volts. i think all of the transistors
are broken now. i will have to buy new ones next week.
Yes it is. You have no flyback diode or output load to prevent voltage breakdown of the transistor.
Likes sysprog
  1. There is about 2 Amps flowing thru the transistor when it is On and you stated it was rated at 1 Amp.
    • Use Ohms Law to calculate the Collector current based on the battery voltage and the resistance in series with the collector; then select a resistor to limit the current to about 1/2 Amp.
  2. The transistor Emitter appears connected to the wrong place, or the 555 chip is wired wrong, or the schematic is wrong. Please correct and let us know.
  3. Please show on the schematic:
    • The 555 pin numbers (and their names if you can)
    • All parts values (transistor, resistors, capacitors, battery)
Since the transistors seem to be shorted, the batteries may be dead. Check their voltage, both when they are not connected to anything and when they are supplying the circuit.
The 555 is running at a frequency about 2.4Hz (2.4 pulses per second) which is much too slow for the small induction coil you are using. You are wasting at least 90% of the battery energy by converting it to heat in the 6 Ohm resistor and the coil.
I suggest changing the 120 microfarad capacitor to 5 microfarads. You won't be draining the batteries so fast, and it will get you a frequency about 58Hz, which would be within the AC measurement range of you meter. This can be changed later if you need a different frequency.
Likes sysprog
the transistor's emitter is connected to the negative power supply.
should i connect the flyback diode to the transistor's collector?
If you like. Get it the right way round though.
Likes sysprog
would using thicker wires for the primary coil and keeping the secondary at gauge 28 increase the voltage in the secondary coil?
i was using the induction coil, then i heard a popping sound. i measured the voltage of the lithium ion cell. before the popping sound the lithium ion cell had a voltage of 4.01 volts. after the popping sound, the lithium ion cell has a voltage of 1.01 volts. is it possible the induction coil damage the lithium ion cell? the lithium ion cell was connected to a 6 ohm resistor.
Sounds like you shorted out the battery - or overloaded it, despite the 6Ω resistor. What is the spec of the battery?
it is a 18650 lithium ion cell that i removed from a laptop battery. it always powered the electronic circuit i used.
Assume one cell produces about 3.6V then the maximum current that can flow through your 6Ω series R will be 600mA. If the cell came from a laptop then that would not be likely to kill it unless you left it running for some while.
Just to clear things up, are you discussing a Cell or a Battery?
PS you could try improving your graphics output. I couldn't read that sketch at all.
i opened up a laptop battery. i found 6 cells in that laptop battery. i removed 6 18650 lithium ion cells from the
laptop battery. i used 4 18650 lithium ion cells in series to power this circuit. each 18650 lithium ion cell has 4.1 volts at maximum charge. i removed 1 18650 lithium ion cell and measured the voltage to be 1.01 volts. i think i am discussing cell not battery.
Looks as if the cell is dead. Was the 6Ω in series with the cell or the whole battery? This is where a proper diagram would let us all get somewhere with this problem.
i taped wires to the 18650 lithium ion cells, connecting 4 lithium ion cells in series. the 6 ohm resistor was connected to 4 18650 lithium ion cells in series.
  • #31
It's still not obvious what you are doing here but it looks as if your short circuit current was Four times the 600mA I suggested, which means a 2.4A drain on your cells to start with. This may mean you have exceeded the 1C discharge rate (depending).
Taking the cells our of the box means that there is none of the protection that you get within the battery .
That suggests your contact may not be good and that you now have a high resistance contact with your wires. Did you try Solder?
Do you seriously have a problem supplying PF with a decent schematic diagram? If you are trying to self-educate then IT is a topic that you could benefit from.
  • #32
is this a proper schematic . i was alternately disconnecting and connecting wires.
  • #33
Much better thanks.
Did you ever look at designs for induction coil circuits? They include a Capacitor to increase the Primary pulse voltage due to resonance. You put the C across the opening contact gap.
  • #34
i tried looking for websites that explain how to design a induction coils. could you show me a schematic of an induction coil circuit.
  • #35
Another thing that could help your iT skills would be more practice with search engines. Asking PF is not the best way forward. Search with the terms in your last post and you should get somewhere. PF is not a spoon feeding service and I think this point has been made to you already.
Likes russ_watters
1. What is an induction coil?
An induction coil is an electrical component that is used to convert low voltage, high current electricity into high voltage, low current electricity. It typically consists of two coils of wire, one inside the other, and is commonly used in applications such as transformers and spark plugs.
2. How does an induction coil work?
An induction coil works on the principle of electromagnetic induction, which states that a changing magnetic field can induce an electric current in a nearby conductor. In an induction coil, the primary coil is connected to an alternating current source, which creates a constantly changing magnetic field. This field then induces a current in the secondary coil, which can be stepped up or down depending on the number of windings in each coil.
3. What materials are needed to build an induction coil?
To build an induction coil, you will need a power source (such as a battery or AC power supply), two coils of wire, a core material (such as iron or ferrite), and a switch to control the flow of electricity. You may also need additional materials for insulation and to create a stable base for the coil.
4. What are some common uses for induction coils?
Induction coils have a wide range of applications, including power transformers, ignition coils in car engines, induction heating for cooking and industrial processes, and medical equipment such as MRI machines. They are also commonly used in science experiments and demonstrations, such as creating electrical sparks or powering a Jacob's ladder.
5. Are there any safety precautions to keep in mind when building an induction coil?
Yes, there are several safety precautions to keep in mind when building an induction coil. First, make sure to use insulated wire to prevent electric shock. Also, be careful when handling high voltage components and always use proper protective gear. Additionally, never touch the coil while it is powered on and always disconnect the power source before making any adjustments or repairs.
  • Electrical Engineering
  • Electromagnetism
