I tried building an induction coil
34 replies · 4K views · last reply
David lopez said:
i taped wires to the 18650 lithium ion cells, connecting 4 lithium ion cells in series. the 6 ohm resistor was connected to 4 18650 lithium ion cells in series.
It's still not obvious what you are doing here but it looks as if your short circuit current was Four times the 600mA I suggested, which means a 2.4A drain on your cells to start with. This may mean you have exceeded the 1C discharge rate (depending).
Taking the cells our of the box means that there is none of the protection that you get within the battery .
That suggests your contact may not be good and that you now have a high resistance contact with your wires. Did you try Solder?
Do you seriously have a problem supplying PF with a decent schematic diagram? If you are trying to self-educate then IT is a topic that you could benefit from.
Hand-drawn circuit schematic: four cells labelled 4.1 volt in series with a 6 ohm resistor on the bottom wire, feeding a coil on the left, and a second coil on the right with a voltmeter symbol marked V.
is this a proper schematic . i was alternately disconnecting and connecting wires.
Much better thanks.
Did you ever look at designs for induction coil circuits? They include a Capacitor to increase the Primary pulse voltage due to resonance. You put the C across the opening contact gap.
i tried looking for websites that explain how to design a induction coils. could you show me a schematic of an induction coil circuit.
Another thing that could help your iT skills would be more practice with search engines. Asking PF is not the best way forward. Search with the terms in your last post and you should get somewhere. PF is not a spoon feeding service and I think this point has been made to you already.
