Ideal Gas Law with spring, no numbers, closed container
9 replies · 8K views
MrMaterial
The closed cylinder of the figure has a tight-fitting but frictionless piston of mass M. the piston is in equilibrium when the left chamber has pressure p0 and length L0 while the spring on the right is compressed by ΔL.
a. What is ΔL in terms of p0, L0, A, M, and k?
b. Suppose the piston is moved a small distance x to the right. Find an expression for the net force on the piston. Assume all motions are slow enough for the gas to remain at the same temperature as its surroundings
c. If released, the piston will oscillate around the equilibrium position. Assuming x << L0 find an expression for the oscillation period T.
for a.
Not quite sure, All this chapter in the book really taught me was the Ideal Gas Law pV = nRT
Given that the question is concerned that I include M I suppose they want me to use kinematics? I don't know how M (mass of the piston) affects the gasses, or ΔL.
I know pressure = Force/Area, and Force = Mass X Acceleration -k X Δx since it's a spring
for b.
force of spring = -kΔx
p1 = nRT/V1
V=A*L0
p1*v1 = p2*v2
for c.
not sure
Note: spring is being compressed, p=0 on other side of piston
first off, V1 = A*L0
then p1 = (-kΔL)/A (I'm lead to believe p = 0 when ΔL = 0
I need to fit in M somewhere to fulfill a.
p1*A = Fsp = -kΔL or, since it's a Force, M*acceleration.
need k, cross out F=Ma approach
what does M effect?
  • not volume
  • not temperature
  • movement
  • pressure?
  • Fsp?
I wonder... Potential spring energy is Usp = 1/2k * Δx^2...
Kinetic energy is 1/2m * v^2
could I turn the isothermal (p1v1 = p2v2) into kinematics? energy?
forces to the right are sourced from p1 and forces to the left are sourced from the spring
p1 = 1/V1
V1 = A*L0... but plus ΔL if it ever gets larger or smaller
p1 = 1/(A*(L0+ΔL))
equilibrium let's p1 also equal Fsp/A
-k*ΔL/A = 1/(A*(L0+ΔL))
I think I am stuck here
I need some clues, or hints as to how I should approach this. I feel that once I find out how M effects ΔL the rest won't be so hard!
For part A, I don't think you need all the properties. For example the mass will probably be a component of part C but for part A just do a free body diagram on the mass. The mass isn't moving so the force from the gas = the force from the spring
That's what's so confusing to me that there's really not too much to say about the system when it's in that state! Yet a. is asking for... an equation by the sound of it. That seems to be impossible so I will assume you are right about that.
I might as well move on to b.
There is an equation. If you do a free body diagram on he mass M the force pushing to the right is P0*A. The force pushing on the mass by the spring is k*ΔL. Set them equal to each other because the forces are equal and solve for ΔL.
Part b the mass is moved to the right a very small distance x. This is where you use the ideal gas law but to=tf so Po*Vo=Pf*Vf
You know Po, V0 is lo*A, the new Vf is (Lo+x) * A solve for Pf. Force f is Pf*A
Part c. Since x is small this is simple harmonic motion for a spring
ok so I did up part a.
decided I should find the force of pressure Fp
p=F/A
so Fp = p*A
p=nRT/V
v=A*(L0+ΔL)
combine them both into
nRT/A*(L0+ΔL) * A = Fp
simplified
Fp = nRT/(L0+ΔL)
Fsp(-kΔL) Fp(nRT/(L0+ΔL)
and that's all I could do for a.
For b. I made a Fnet equation:
Fnet = Fsp + Fp
Left is negative and Right is positive
Fnet = -kΔL + nRT/(L0+ΔL)
T stays the same so obviously the Fnet is going to go left, and real quick unless there is a substantial gain in T (which there isn't)
Attempting c. need to find out how to do oscillations... and what "x << L0" even means!
note, on a. when it said to show ΔL in terms of p0, L0, A, M, and k, I interpreted that as something like "find an equation to solve ΔL using these variables" I must have been mistaken
What's the definition for the period of a spring/mass system in simple harmonic motion?
i slightly remember doing stuff like that two quarters ago. Going to have to look through some notes I guess!
So close to answering c.
5 hours of straight physics, and I can't refresh myself with kinematics. Gonna try this again tomorrow morning and see if I can answer it.
c.
ω = √k/M
so 2pi/T = √k/M
2pi = T*√k/M
2pi/√k/M = T
I guess that's all they ask for!
