Ideas for refrigerator door design
- Thread starter Trainee Engineering
- Start date
- Tags
- Design Ideas Refrigerator
46 replies · 11K views
256bits
- 2,301
The functional side of ergonomics seems to be a square-ish box with a door for accessibility and standing on the floor seems to be the common design for a refrigerator. What about a counter top model wider than it is high, with several doors along its length? At least that would be good for someone with back problems and bending over issues, or wheelchair people who have trouble reaching to the high spots.. One could run with that for a re-design of kitchen placement of counters and cabinets and storage. all it needs is architectural imagination.Sue Rich said:The idea of glass doors is so-so. As a woman and a mom who raised a lot of children (and cooked a gillion meals) those would be okay, but there are more important things to women of any age; pull out shelves and drawers in both fridge and freezer, or even revolving shelves. Most women face the problem of not being able to find something when they need it, or unloading most of the unit to locate the item. Too, we forget some of the things we've bought until it's too late. Hence, throwing away money. We need better accessibility.
- 11,327
- 8,758
Trainee Engineering
- 52
- 1
my fridge volume is 473 litre (freezer and refrigerator compartment). defrost takes around 190W around 40 mins to 1 hour.
light bulb is around 10W.
average consumption per day is 1.3 - 1.5 kWh.
as for the issue of difference of leaving the door open for 5 secs vs 30 secs, pretty sure more heat will enter the compartment the longer the door is opened. heat transfer is a time function after all.
so, the longer the door is opened, the more electricity will be consumed to restore the temperature in the compartment to "normal"
XZ923
- 136
- 62
Sorry if it's already been suggested, but what about compartmentalizing the fridge so only smaller areas at a time are exposed to the outside air? Also the door could probably be designed with an acrylic rather than mineral glass.
OmCheeto
- 3,679
How do you know that?Trainee Engineering said:...
It's actually very interesting, when you graph it:
Door opened for 74 seconds:
Door opened for 5 seconds:
time lag of my detector:
OmCheeto
- 3,679
I was involved in an argument a while back regarding the term "most".DrClaude said:This seems to corroborate my intuition: most of the cold air escapes in the first ~10 seconds.
I very much liked marcus's answer to the question:
marcus said:I certainly agree his wording ("most" of the mass) was ill-advised even if technically correct. "Most" suggests a substantial majority (at least to me and probably to most people) rather than a very slim majority like 50.1% versus 49.9%. Gives the wrong impression --- mostly a matter of nuance.
I propose, in a most off topic manner, that someone start a poll, in another thread, as to how we should scientifically define the term "most".
Personally, I like the 1/√2
OCR
- 996
- 936
DrClaude said:Yes, I meant how much negative heat is lost![]()
OCR
- 996
- 936
I'll bet you meant...DrClaude said:This seems to corroborate my intuition: most of the cold air escapes in the first ~10 seconds.
: most of thecoldnegative hot air escapes in the first ~10 seconds.
NTL2009
- 637
- 393
If you are using a Kill-a-watt meter, or equiv, couldn't you compare overnight kWh to daytime kWh? You'd need to manually log the kWh and time before bed and in the AM, but a week's worth of data should average out the defrost cycles.OmCheeto said:"out of town"?
That doesn't happen very often for me.
But your's is a very good idea.
Though, it may extend this experiment into the "months" range.
But, as an oldster, I'm getting somewhat used to long range experiments.
ps. I will pay someone actual currency, if they can determine which continent jtbell's image is from...
on Tuesday, of course.
Trainee Engineering
- 52
- 1
OmCheeto said:How do you know that?
using Kill A Watt. I plug the Kill A Watt at 1AM 4 days ago, and I read everyday at 1AM.
as for your graph, this is very interesting. the temp indeed increase more as more time goes by, but the significant loss is at the first 10 seconds. I guess that's the cold air leaking out, but negative heat from solids (stuff actually inside fridge) takes longer to transfer out to environment.
OmCheeto
- 3,679
@T=180 hours(7.5 days), the energy consumed was 27.69 kwh, which corresponds to an average power of 152 watts.NTL2009 said:If you are using a Kill-a-watt meter, or equiv, couldn't you compare overnight kWh to daytime kWh? You'd need to manually log the kWh and time before bed and in the AM, but a week's worth of data should average out the defrost cycles.
Great devices!Trainee Engineering said:using Kill A Watt...
I've learned a lot about my refrigerator from the data I've collected over the last week.
One peculiarity during this experiment, was that my refrigerator operated at between 210 & 228 watts.
It wasn't until I accidentally triggered it to turn on, and start recording data every minute, that I found out why.
For some reason, instantaneous power consumption goes down with time, after the compressor has started running.
And I think I may have captured the defrost cycle:
"watts rough" is the the wattage between readings
"watts smooth" is the wattage from time = 14 hours
Entertaining numbers:
On or about t=20 hours, I went out for lunch, in an attempt not to booger my "DON'T OPEN THE REFRIGERATOR DOOR!" experiment, and spent $7.35 for lunch.
From my extrapolation of data so far, it costs me $13.55 to run my refrigerator for a month.
Conclusion: Eating out, even at Taco Bell, is kind of expensive.
Trainee Engineering
- 52
- 1
OmCheeto said:@T=180 hours(7.5 days), the energy consumed was 27.69 kwh, which corresponds to an average power of 152 watts.
Great devices!
hmm, $13.55, may I have the kWh? because price per kWh from one country to another is different, but kWh remains constant anywhere. a bit curious about the energy consumption when door not opened.
Buckleymanor
- 644
- 26
Try this.http://www.explainthatstuff.com/electrochromic-windows.htmlrumborak said:I would argue that transparency is actually not desirable for kitchen fridges, from a user's perspective.
OmCheeto
- 3,679
This can be calculated with the the data from the first line of mine that you quoted;" ...which corresponds to an average power of 152 watts"Trainee Engineering said:hmm, $13.55, may I have the kWh? because price per kWh from one country to another is different, but kWh remains constant anywhere. a bit curious about the energy consumption when door not opened.
152 watts * 24 hours / 1000 = 3.65 kwh/day
So your refrigerator uses less than half what mine does.Trainee Engineering said:average consumption per day is 1.3 - 1.5 kWh.
When I discovered that, I looked into purchasing the fancy refrigerator rbelli1 referenced earlier:
Cost: $5,600rbelli1 said:
I did some fancy maths and discovered it would take about 59 years for the refrigerator to pay for itself.
I decided against the purchase.
rbelli1
- 446
OmCheeto said:Cost: $5,600
I was just saying it was a thing. I had no idea what it cost. Please don't buy it and encourage them. The couple hundred dollars for the parts gets them a few thousand extra in product cost.
OmCheeto said:For some reason, instantaneous power consumption goes down with time, after the compressor has started running.
The temperature difference decreases over time with the operation of the cooling device. The power needed to operate the compressor decreases with a decrease in temperature differential. Quod erat demonstrandum.
BoB
- Ranger Mike
- · Replies 33 ·
- Mechanical Engineering
- Replies
- 33
- techsingularity2042
- · Replies 5 ·
- Introductory Physics Homework Help
- Replies
- 5
- ShizukaSm
- · Replies 6 ·
- Replies
- 6
- Slickepot
- · Replies 21 ·
- Mechanics
- Replies
- 21
- NintendoKD
- · Replies 7 ·
- Replies
- 7
- misko
- · Replies 13 ·
- Mechanics
- Replies
- 13
- duran9987
- · Replies 3 ·
- Replies
- 3
- AzMaphysics
- · Replies 9 ·
- Replies
- 9
- graphicer89
- · Replies 6 ·
- Replies
- 6
- sltungle
- · Replies 2 ·
- Replies
- 2
