Identifying cusp catastrophes?
  • Thread starter Thread starter Set Abominae
Set Abominae
Hi everyone.
I have a system with two strictly positive parameters, for which we have a single equilibrium point or 3 equilibrium points if a certain inequality holds involving the two parameters.
I'm struggling to identify whether or not this is an example of a cusp catastrophe or not.
I know I'm supposed to be looking at the following equations:
V(x)=(x^4)/4 + (ax^2)/2 + bx
and
4(a^3) + 27(b^2) = 0
,but I'm generally unsure as to how to proceed.
Any nudges in the right direction would be helpful (I'm not listing the equations because I'm only looking for help with the theory...)
Thanks in advance, everyone :)
Mathematics news on Phys.org
To receive a meaningful answer, you will have to explain your explanation first. It is not clear how your equilibriums are defined.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
