If A is nilpotent , prove that the matrix ( I+ A ) is invertible
  • Thread starter Thread starter Maths Lover
    Matrix
If A is nilpotent, then the matrix (I + A) is proven to be invertible by constructing its inverse as a series involving powers of A. The discussion highlights attempts to find the inverse, particularly for even and odd values of K, where A^k = 0. A successful approach involves expressing the inverse as a polynomial series: (1 - A + A^2 - A^3 + ... + (-1)^n A^n). The participants also explore alternative proofs of invertibility without explicitly finding the inverse, emphasizing the importance of understanding the underlying concepts. The conversation concludes with a positive acknowledgment of the collaborative problem-solving process.
Maths Lover
if A is nilpotent " A^k = 0 , for some K > 0 " , prove that the matrix ( I+ A ) is invertible ..
I found more than a topic in the website talk about this theorem biu every one of them didn't produce a complete proof !
I found the question in artin book and I tried to solve this problem and I solved it when K is even , I could calculate the inverse but I hope to find the hole proof here ..
Please show an attempt at the solution. For example, how did you solve the even case?
My attempt is wrong !
I've found that it's wrong , any way here is it
( 1 + A ) ( 1 - A ) = 1 - A^2 : 1 denote I matrix
( 1 - A^2 ) ( 1 + A^2 ) = 1 - A^4
continue in that way , if k is even , so the power of A is even to and the power of A " let us denote it by n " will take every possible even number
when you multiply time ater time n will be equal to K then A^k = 0 so
( 1 + A ) ( 1 - A ) ( 1 + A^2 ) ... ( 1 + A^ c ) = 1
where 1 + 1 + 2 + 4 + 4 + 8 + ..+ c = K
so " ( 1 - A ) ( 1 + A^2 ) ... ( 1 + A^ c ) " is the inverse
but that is not true because K may be 6 for example but you can't get 6 with this way
so this way is useful when K = 2^ m
that's my attempt
What way can you get 6?
Alternatively, if you can't make 6, can you still do with 4 or 8 or something else?
So, if I understand you right, you want to find an inverse of the form
a_0 I+ a_1 A + a_2 A^2 + ... + a_n A^n
where A^{n+1}=0.
Now, why don't you multiply
(I+A)(a_0 I+ a_1 A + a_2 A^2 + ... + a_n A^n)
this to see what you can take as a_i?
I read your reply before you edit it :))
you are right I can make A^ 8 = A^6 * A^2 = 0
so it's useful for even numbers :))
thanks a lot , I forgot that if A^k = 0 then A^(k+n) = 0 : n >0
Thanks , But do you know a complete proof ?
Yes, we know the complete proof. But the idea is that you should figure out yourself instead of us telling you what it is.
I understand , I tried to solve the problem when K is odd , but my mistake was that I use the inverse of A and I forgot that A is not invertible !
Did you read Hurkyl's suggestion and my suggestion? Certainly that will give you something to do?
where A^{n+1}=0.
I found that : if we make
a(n) = -a(n+1)
then ,
a0 I + a1 A + a2 A^2 + .. + an A^n
the sum will be ( a0 * I )
so , let a0 = 1 then a1 = -1 then a2 = 1 and so on I will get the I matrix
so
the matrix
( 1 - A + A^2 - A^3 + ... (-+)A^n )
is the inversr of ( I + A)
Is that right ?!
yes , I did .. I replied both of you
a(n) = -a(n+1)
then ,
so
the matrix
Is that right ?!
Yes, that is right. That is indeed the inverse of I+A.
ok , Thank you very much :))
and my greetings to Hurkyl too ..
I want to say something ,
the way that you follow is great " i mean that you made me get the inverse myself and didn't gave it to me " , I tried so much for 2 days to get this inverse but I couldn't , now I'm so happy :))
thank tou again ..
my last question !
Is there a proof which prove that ( 1 + A ) is invertible without getting the inverse ?
I mean , is there a way prove that it's invertible without knowing what is the inverse ?!
Hi everyone .
Maths Boy I advice you to use the Latex codes its very cute .
something like that :
$$I_{3 \times 3} = \begin{bmatrix} 1 & 0 & 0 \\ 0 & 1 & 0 \\ 0 & 0 & 1 \end{bmatrix}$$
enrahim3enab said:
Hi everyone .
I don't know how to use latex codes !
  • · Replies 40 ·
  • · Replies 25 ·
20K
