If the integral is zero, when is the integrand also zero?
  • Thread starter Thread starter plasmoid
    Integral Zero
If the integral of a function multiplied by an exponential term equals zero, it does not necessarily imply that the function itself is zero everywhere. The discussion highlights that this scenario represents an integral transform rather than an expansion in an orthonormal basis. It is possible for the function to be non-zero at a finite number of points while still resulting in a zero integral. The conclusion drawn is that one can assert f(k) = 0 "almost everywhere" or "except on a set of measure zero." Thus, the relationship between the integral being zero and the function itself being zero is not straightforward.
plasmoid
If
\int_{-\infty}^{\infty} f(k) e^{i\mathbf{k}.\mathbf{r}} d\mathbf{k} =0
then is
\ f(k)=0 ?
Is it correct to say that this is an expansion in an orthonormal basis, \ e^{ik.r} , and so linear independence demands that f(k) be zero for all k?
Yep, that works. You can show it explicitly by multiplying both sides by \exp(-i\mathbf{q} \cdot \mathbf{r}) and integrating over r. You should find f(q) = 0. (Assuming f(q) is reasonably 'nice'. I suppose there could be pathological examples where f(q) is non-zero).
I believe that the basis being complete without redundancy is also important. In other words: you can say f(k) = 0, if any function (in your function space) can be expanded in the basis, and in a unique way.
[Edit: probably you can show this to be the case for an orthonormal basis, because it is impossible to express any basis element as (infinite) sum of the others].
plasmoid said:
If
then is
\ f(k)=0 ?
No. This is an integral transform, not an expansion of a function in some orthonormal basis. If f(k) was non-zero at only a finite number of points, you would still get 0 for the integral. You might be able to say f(k) = 0 "almost everywhere" or "except on a set of measure zero".
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
