Ignition switch and Battery cut-off
The ignition switch in a vehicle, specifically the 1972 model discussed, is directly connected to the battery, allowing current to flow to the ignition module when the key is turned to the ignition position. This current is then distributed to the ignition system and accessories, including the alternator. When a battery cut-off switch is installed and turned off, it completely disconnects the battery from the vehicle, rendering the ignition system inoperative. The master cut-off switch is typically wired between the negative battery post and the chassis ground, ensuring that when it is off, the entire vehicle is powered down.
  • Understanding of automotive electrical systems
  • Familiarity with ignition systems and their components
  • Knowledge of battery cut-off switch installation
  • Basic wiring principles in automotive applications
  • Research the wiring diagram for a 1972 ignition switch
  • Learn about the function of ignition modules in modern vehicles
  • Explore different types of battery cut-off switches and their applications
  • Investigate the impact of disconnecting the battery on vehicle electronics
Automotive technicians, electrical engineers, and DIY car enthusiasts looking to understand ignition systems and battery management in vehicles.
AM1990
I have a question that how ignition switch works.
Is it is directly connected to battery..? or Alternator..??
Further If I apply a Battery Cut-Off Switch, will ignition works when Battery Cut-Off Switch is off..??
Perhaps you can answer your own questions using this diagram.
on the 1972 ignition switch you show, the current runs from the battery to the ignition key on the steering column. When you move key to the ignition position the juice flows to the ignition module. It is then distributed to the ignition and various accessories to include alternator. The number 2 key position is to actuate a moment switch that throws power to the starter solenoid to spin the dc starter motor. Juice is cut once you let off the key switch and the small spring returns the key to position number 1.
A Master cut of switch usually is a switch placed in line between the negative battery post and the ground point on the chassis. When it is OFF the whole car is dead, You can wire in a master switch a number of different ways but this is the typical method.
  • · Replies 39 ·
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 32 ·
13K
