I'm blind when it comes to angles
  • Thread starter Thread starter rocomath
    Angles
The discussion centers on the accuracy of a force diagram and the potential error in the teacher's solutions. Participants confirm that the angles in the diagram are correct and suggest visualizing the N-T axes superimposed on the y-x axes before rotating the N-T system. This rotation helps clarify the relationship between the angles and the axes. Additionally, advice is provided on how to approach placing angles correctly in the diagram. Understanding the rotation of the axes is key to resolving any confusion about angle placement.
rocomath
did i set up my force diagram right? my teacher gave us soln's but i think there's an error.
also, could i get advice on how to approach determining how to place the angles correctly in the diagram, I'm blind.
thanks!
http://img136.imageshack.us/img136/5711/angleqg6.jpg
Your angles are right.
Try imagine the N,T-axes to initially have been superimposed on the y,x-axes, respectively.
Then rotate the N-T system so that T gains angle theta to the x-axis.
Therefore, the angle between the N and y axes must also be theta.
