I'm confused about the work energy theorem
The work-energy theorem, expressed as ΣW = ΔKE, focuses solely on kinetic energy changes, as potential energy is inherently accounted for by the work done against gravity. When lifting an object, such as an apple, the work done against gravity (mgh) is countered by gravity's negative work, resulting in a net work that reflects only changes in kinetic energy. The theorem applies universally, indicating that net work is only done when an object's speed changes. Thus, potential energy is not excluded but rather integrated into the work calculations, reinforcing the theorem's foundation in Newton's second law.
  • Understanding of Newton's second law of motion
  • Familiarity with kinetic energy and potential energy concepts
  • Basic knowledge of work and energy principles
  • Ability to perform calculations involving gravitational forces
  • Study the derivation of the work-energy theorem in classical mechanics
  • Explore the relationship between work done by conservative forces and potential energy
  • Learn about energy conservation principles in closed systems
  • Investigate real-world applications of the work-energy theorem in engineering
Students of physics, educators teaching mechanics, and engineers applying energy principles in design and analysis will benefit from this discussion.
reyrey389
The reason why the work energy theorem " ΣW = Δ KE " only includes kinetic and not potential energy, is because gravity undoes the potential energy ? What I mean by "undoes" here is, If you were to, for e.g., lift an apple up a vertical distance, but also accelerate it while lifting it. Then you would do +mgh joules of work to lift it and +1/2 mv^2 to accelerate it, but gravity did -mgh work, so the total was just kinetic. So that theorem will only contain kinetic energy ? Or is it only for this certain case where it does not ? If the former is true, and mass stays constant, can the theorem simply be stated as net work is only done if objects change their speed ?This somewhat seems to make sense because if you lift the apple at a constant speed instead of accelerating it you did +mgh joules of work on it , but gravity did -mgh work, so the net work was 0. And since the apple didn't pick up or lose any speed, there was no net work done on it.Then again, it somewhat doesn't make sense because even though the speed of the apple didn't change, we expended energy to lift it, and at its highest point it now has stored energy. There was no energy initially (assume initial position = 0) and now there is energy mgh, so shouldn't there be some work done on the apple ?
The potential energy is just an alternate way to take into account the work done by gravity or other conservative forces.
If you include the potential energy then the work in that formula won't be the net (total) work but just the work of the forces not associated with potential energies.
So in your formula, the sum over W is the net work, the work of all forces, including gravity. Gravity is not excluded.
However, by definition, the work done by gravity is equal to the change in potential energy, with a minus sign. So the potential energy is not excluded but counted in the work side of the formula. If you want to count it as explicit;y PE, you move in on the other side and the negative sign becomes positive.
But you don't need to look for complicated reasons. The work-energy theorem is a direct consequence of Newton's second law. Introduction of potential energies is like a further "refinement".
  • · Replies 21 ·
  • · Replies 77 ·
  • · Replies 54 ·
  • · Replies 31 ·
  • · Replies 16 ·
