Image formation in concave mirrors
Concave mirrors can produce real images that can be captured on a screen, unlike flat mirrors, which only create virtual images. When observing an inverted image in a concave mirror, it may appear to be behind the mirror due to the straight-line travel of light rays to the observer's eye. To capture this real image, a bright object must be positioned correctly above the mirror's center line, with a screen placed below it without blocking the light. Additionally, using a pointer like a pencil can demonstrate that the image and the object can appear to be aligned, indicating they occupy the same spatial location. This phenomenon highlights the unique properties of curved mirrors in image formation.
rishch
When you look in spoon from a reasonable distance you see an inverted image of yourself in the mirror. How can you see a real image in the mirror when I thought you saw virtual images in a mirror and real images had to be caught on a screen.
Science news on Phys.org
The inverted image "floats" in front of the mirror. It's possible (at least in principle) to capture it on paper. Use a bright enough object (maybe a small light bulb), hold it above the center line (axis) of the mirror, and hold the paper below the center line. You don't want the paper to block the light going from the bulb to the mirror.
You probably heard that a flat mirror can't create a real image. This is certainly not the case for a curved mirror.
Yes I know that a plane mirror can't create a real image. But I see an inverted image that looks like it's behind the metal, when I thought it forms a real image in front that you can capture on a screen.
The image appears at first glance to be behind the mirror because you can see it only via light rays that travel in a straight line from the mirror to your eye. You can't see the image "from the side", so to speak.
As I described above, it is possible to capture such an image on a screen, if the object is bright enough and you position the object and screen properly so the screen doesn't block the light traveling from the object to the mirror.
Here's another thing you can try. Hold a pencil or other pointer-like object in front of the mirror. You should be able to place it in such a position that the image appears to be "stuck" to it. (By "it" I mean the pencil itself, not its image in the mirror!) That is, you can move your head and eye from side to side with the pencil and the image staying together. This is not possible if the image is behind the mirror and the pencil is in front of the mirror; they both have to be in the same location.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
