Image Formation Issue: Spherical Aberration & Fixing
  • Context: Undergrad
  • Thread starter Thread starter yas-say
    Formation Image
The discussion revolves around the simulation of image formation in the eye, specifically addressing issues related to spherical aberration in lens behavior. Participants explore whether it is feasible to continue with image formation despite the presence of aberration and how to potentially fix it, while also considering the implications of using different lens shapes, such as parabolic versus spherical lenses.
  • One participant notes that the refracted rays not intersecting at a single point may be due to spherical aberration.
  • Another suggests that using a thinner lens could reduce the effects of spherical aberration and proposes modeling a perfect lens to understand basic image formation.
  • There is a question about whether a parabolic lens is necessary for perfection in image formation, with some uncertainty about the equivalence of parabolic and spherical lenses.
  • A participant expresses doubt about the applicability of equations for perfect lenses to real-world scenarios involving curved surfaces like the retina.
  • Concerns are raised about the limitations of using spherical lenses in eye models, with a suggestion to start with a perfect model and gradually introduce aberrations.
  • One participant asks for clarification on the derivation of equations related to lens behavior and their applicability to thick lenses.
  • There is mention of attempting to refract rays on a spherical surface, indicating ongoing issues with the simulation.
Participants do not reach a consensus on whether to continue with the spherical lens model or switch to a parabolic lens. There are multiple competing views regarding the necessity and implications of using different lens shapes, and the discussion remains unresolved regarding the best approach to handle spherical aberration.
Participants express uncertainty about the effectiveness of equations derived for perfect lenses when applied to real-world scenarios, particularly concerning the curvature of the retina and the nature of spherical versus parabolic lenses. There are unresolved questions about the applicability of certain equations to thick lenses and the specific conditions under which they hold true.
yas-say
Hi guys
I've been trying to make a program that simulates image formation in the eye
so I simulated a spherical lens behavior in 3d coordinates
and I'm facing a strange results!
is it normal that the refracted rays don't intersect all at the same point
I began to think it's true because of the spherical aberration.
here's the problem:
can I continue with Image formation with this aberration or should I fix it
If I should how could I?
any help would be great
thanks in advance
Science news on Phys.org
Yes, its probably spherical aberration. The thinner the lens is, the less problem there should be. You could model a perfect lens, one that has no aberrations whatsoever. I forget what shape that is, it might be a parabola. Anyway, modelling the eye as a perfect lens will take care of the basic image formation, and then if you want to deal with lens aberrations in the eye, start introducing deviations from the perfect lens. Like if you want to model astigmatism or something.
A perfect lens would be one that was infinitely thin, and every ray parallel to the axis of the lens would pass through the focal point. Any ray (parallel or not) passing through the center of the lens will be undeflected. The equation for a perfect lens is - if a ray hits the lens at angle "a" to the normal, a distance z from the center of the lens, and the lens has focal length "f", then the ray will exit at angle a' where
Tan(a')=z/f - Tan(a)
So if I want perfection I have to simulate a parabolic lens?
but can I simulate a spherical lens with the aberration and still image formation works
because all eye models are based on spherical lenses
if not, can I an equivalent parabolic lens from a spherical one
and what is the equation of a parabola in 3d space
Im not sure a perfect lens is parabolic, but I gave the equations above. But these equations are for perfect image formation on a flat plane, not on the curved surface of the retina, so maybe these will not work well, I'm not sure.
If all eye models are based on spherical lenses, then perhaps you should stick with the spherical lens and realize that image formation will not be perfect. But If I model something, I like to start with a simple, perfect example, and then introduce the problems one at a time and note their effect on the result.
I studied a little about lenses and I didn't come across this equation so could you tell me
where did it come from is it derived from snell's law, could you tell me about it
does it work for thick lenses.
and by the way I tried to refract rays on a spherical surface so it's basically moving from one medium to another and the problem still exists.
I'm sorry for bothering you and I'll pay you later :shy:
  • · Replies 24 ·
  • · Replies 16 ·
  • · Replies 20 ·
