In a system in void oscillates eigenfrequency
  • Thread starter Thread starter mather
    System
In a system oscillating at its eigenfrequency, applying a periodic force at the same frequency can lead to infinite energy and oscillation width. If the force frequency differs from the eigenfrequency, the system will absorb energy but also lose some due to misalignment in timing. The evolution of energy in response to varying force frequencies can be described by the equation d^2x/dt^2 + kx = f(x), which incorporates both kinetic and potential energy. A periodic force with a frequency different from the eigenfrequency can still increase energy, albeit at a slower rate. Variations in the force's frequency could lead to complex outcomes, including resonance effects or energy dissipation.
mather
hello!
in a system in void oscillates (eg a mass tied in a spring, whose other edge is fixed)
we say that if we exert a periodic force to it, with the same frequency that it oscillates (eigenfrequency), then its energy and oscillation width becomes infinite
if the periodic force has not exactly the same frequency, the system will gather energy from the force, but it will also lose energy, since the force won't be exerted at the correct moments, each time
however, which function calculates the evolution of the energy of the system, according to various frequencies of the exerted force?
thanks!
The equation is d^2x/dt^2+ kx= f(x). If we let v= dx/dt, then d^2x/dt^2= (dv/dt)= (dv/dx)(dx/dt)= v(dv/dx. Then we have v(dv/dx)= f(x)- kx so we can write vdv= (f(x)- kx) dx and, integrating both sides, (1/2)v^2= \int f(x)- (k/2)x^2+ C. That is the same as (1/2)v^2+ (k/2)x^2=\int f(x)dx+ C
The left side is the total energy, kinetic plus potential, so that if there were no "f(x)", it would reflect "conservation of energy" in a closed system. With f(x), \int f(x)dx is the external energy that is "pumped" into (when f(x) is positive) or out of (when f(x) is negative) the system.
HallsofIvy said:
The equation is d^2x/dt^2+ kx= f(x). If we let v= dx/dt, then d^2x/dt^2= (dv/dt)= (dv/dx)(dx/dt)= v(dv/dx). Then we have v(dv/dx)= f(x)- kx so we can write vdv= (f(x)- kx) dx and, integrating both sides, (1/2)v^2= \int f(x)- (k/2)x^2+ C. That is the same as (1/2)v^2+ (k/2)x^2=\int f(x)dx+ C<br /> The left side is the total energy, kinetic plus potential, so that if there were no &quot;f(x)&quot;, it would reflect &quot;conservation of energy&quot; in a closed system. With f(x), \int f(x)dx is the external energy that is &quot;pumped&quot; into (when f(x) is positive) or out of (when f(x) is negative) the system.
<br /> <br /> thanks but i didnt understand a thing<br /> <br /> my question basically is: how will a periodic force with frequency different than oscillating system&#039;s eigenfrequency, affect the energy of the system?<br /> <br /> would it possible to increase it, in a slower manner than if it had the same frequency as the eigenfrequency?<br /> <br /> also, a graph would help<br /> <br /> also, what about if the force&#039;s frequency varies? what would be the possible outcomes of that interaction?
anyone?
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
