In dealing with differential equations
5 replies · 2K views
Badgerspin
Ok, I've been working this one out for a while, and I just can't seem to get it.
I'm looking for the condition such that x(t)=k (where in our class, K generally equals e^c)
The initial equation is as such:
7t^2(dx/dt)+3x+5=0
I've worked the equation down to two different forms:
x = (-e^((3/7t)-3c)-5)/3
and
x = c*e^(3/7t) - 3/5
For the life of me, I can't figure out what K (or C I suppose) equals in order so that x(t) = k
This is online work, and it only accepts a precise answer for credit.
It's also not letting me enter the variable t as an answer for c (or K), so I'm wondering if there's maybe an error in what was programmed as the correct answer.
I'm sure there's something I'm missing or another way that I need to work the problem. Any help would be appreciated.
You didn't show all your steps but I assume one of your steps might have been:
[tex]\ln (3x+5) = \frac 3 {7t} + 3C[/tex]
leading to
[tex]3x+5 = e^{\frac 3 {7t}+3C}[/tex]
You would normally write this
[tex]3x+5 = e^{3C}e^{\frac 3 {7t}}[/tex]
and rename the e3C as K. Try that.
It's still not letting me enter in a variable as a solution.
I worked it out as shown (thank you).
So:
k = (ke^(3/7t) - 5)/3
or working with k = e^c
((k^3)e^(3/7t)-5)/3
In either case, it's still not letting me enter in any variables. If there's a solution to this problem that's all constants, I can't seem to find it. The only solutions I can come up with all involve the variable t.
I'm a bit confused about what you're looking for. x(t)=k would only hold for some particular value of t, call it [tex]t_0[/tex] and you haven't stated such an initial condition [tex]x(t_0) =k[/tex]. Has one been specified in the problem?
Secondly you refer to a "solution to this problem that's all constants," but you have already found one, which is the particular solution [tex]x_p = -5/3[/tex]. This is of course different from an initial condition.
fzero,
I punched in -5/3 and it said it was correct. When you say different initial conditions, what condition are you talking about? I'm not quite following that.
What I mean is when you have an equation y' = y and are given the initial condition y(0) =1. The general solution is y = c et, but the initial condition requires that c=1. In general you need an initial condition if you want to fix an integration constant.
