In which direction a spherical particle moves under torque?
The discussion revolves around the motion of a spherical particle under the influence of an applied torque in a viscous fluid, specifically addressing the direction of the particle's movement along the y-axis. The context includes low Reynolds number hydrodynamics and the effects of boundary conditions at a stationary wall.
  • Eric presents a scenario involving a spherical particle in a viscous fluid and questions the direction of its velocity along the y-axis when a positive torque is applied.
  • One participant asks for clarification on the orientation of the torque relative to the no-slip boundary, suggesting that a positive torque in the x-direction would lead to opposing motions at the top and bottom of the particle.
  • Eric clarifies that the torque is indeed oriented in a positive (counter-clockwise) direction, leading to confusion about the expected motion direction, which he initially thought would be negative along y.
  • Another participant agrees with Eric's intuition that the motion should be in the -y direction and questions the feasibility of solving the Navier-Stokes equations in this geometry.
  • Further discussion includes references to the use of Stokes equations and mobility calculations, with a link to relevant literature.
  • One participant expresses skepticism about the results, suggesting that any sign error likely originates from the mathematical implementation rather than the physical behavior of the particle.
  • Eric references a specific equation from Swan's paper that indicates a positive sign for the motion, noting that this result is counterintuitive and has historical precedence in earlier work by Goldman.
Participants express differing views on the direction of the particle's motion, with some supporting the idea of motion in the -y direction while others reference mathematical results suggesting a positive direction. The discussion remains unresolved regarding the correct interpretation of the results.
There are limitations related to the assumptions made about the torque's orientation and the mathematical models employed, particularly concerning the applicability of the Stokes equations and the complexities of the Navier-Stokes equations in this scenario.
This discussion may be of interest to researchers and students in fluid dynamics, particularly those exploring the behavior of particles in viscous flows and the implications of torque on motion near boundaries.
Eric
Consider a small rigid spherical particle of radius a, fully immersed in a viscous incompressible Newtonian fluid of shear viscosity η above a hard-wall with stick (no-slip) boundary conditions, located at the plane z = 0. A constant positive (external) torque Tx is applied on the particle.
My question is:
Assuming low Reynolds number hydrodynamics, the particle will move along the y direction due to hydrodynamic interactions. But, does the velocity along y have a positive or negative sign?
Any help would be highly appreciated.
Thank you
Eric
You need to tell us how the torque is oriented relative to the no-slip plane. Maybe you're trying to do that by calling the torque "Tx". Do you mean the torque is parallel to the x direction, and pointing in the positive x direction? This would make the bottom of the marble want to move toward +y and the top of the marble want to move toward -y, since positive torque is counter-clockwise.
Thanks for your reply.
Here the torque is oriented in the positive direction (contour-clockwise) leading to particle motion in the y direction due to hydrodynamic interactions.
Also the wall is stationary (fixed). My calculations lead to motion in y+ while intuitively one would rather expect hat the particle will move in y- (analogy with a particle rolling on a wall) I am totally confused..
It would be great if you could please provide with some hints that may help a bit to figure out what is going on.
Thank you
E
I agree with your intuition. Motion should be in -y direction. I don't think you can solve Navier Stokes very easily by hand in this geometry... what calculations are you doing?
Here only the Stokes equation are solved (nonlinear term is dropped out). The mobility calculations are used, see e.g. Swan,[/PLAIN] J. W. and Brady, J. F., Phys. Fluids 19, 113306 (2007)
Wow that's an interesting paper. I'm impressed that this can be solved, even for a pair of particles as in the appendix. I don't have the heart to look at it closely enough to try and figure out why the math is giving you the wrong sign. Not that it's worth more than two cents, but I'll bet 90:10 odds that the sign error lies somewhere in the math or your implementation of it, and not that the particle really rolls backward when you torque it near a wall.
If you really need a faith boost before you start hunting back through your math, maybe try this out with a xylophone mallet (sphere with attached stick so you can torque it) and a bowl of syrup haha.
Thanks dreens for your helpful insights. The equation stated above corresponds to Eq. (B2) of Swan's paper (the RT tensor is the transpose of TR tensor) and clearly the sign is positive, i.e. counter-intuitively (The equation seems to be a known result and it was first derived by Goldman some decades ago [Slow viscous motion of a sphere parallel to a plane wall- I Motion through a quiescent fluid, Chem. Eng. Sci. 1967]) I will think about it
Thanks again
Kindest regards,
Er
  • · Replies 18 ·
