Inclined ramp inside an accelerating train
The discussion revolves around a physics homework problem involving a body on an inclined ramp inside an accelerating train. The key question is determining the minimal acceleration of the train required for the body to slide up the ramp. Participants suggest using a free body diagram to analyze forces, including static friction, normal force, and gravitational components. Corrections are made regarding the direction of forces and the need to account for the train's acceleration when calculating net forces. The conversation concludes with the student gaining clarity on the problem-solving approach.
jul_greenberg
Hello,
I have a question for homework. The question reads:
A body of mass m=4.8 kg is standing on a ramp inclined in an angle of α=12 degrees. The static friction coeficient between the ramp and the body is μ=0.24. The ramp, which is inclined to the left, is in a train, which accelerates to the right. What is the minimal acceleration of the train that will cause the body to slide up the ramp?
I thought that for the box to slide up force greater than Ff+4.8*9.8*sin(12) should be applied by train (..by friction that is). From there acceleration of train with respect to the box can be calculated. However I unable to figure out how calculate the acceleration with respect to earth.
Would appreciate any advice.
jul_greenberg said:
Hello,
just do a free body diagram picturing the situation as seen from outside the train. There will be a normal force, gravity and the static friction force. Since you want to consider the point when it's just about to slide, use the equation for the maximu static friction force with a magnitude \mu_s N. use the fact that the vertical acceleration is zero to find the value of the normal force (along the y direction you will have gravity acting down an dthe y component of the normal force which will involve "N" and the angle of the plane). Then go along the x direction and impose \sum F_x = m a_x to find a_x.
Thanks for the response nrqed.
Here is my free body diagram.
http://img504.imageshack.us/img504/8239/fbdiahr0.jpg
N = mgcos(O) =>
fs = μN = 0.24*4.8*9.81*cos(12) = 11.054 N
Fnet_x = mgsin(12) + 11.054 = 20.844 N
Fnet_x = ma = 20.844
ax = 4.343 m/s/s
I have suspicion that I am not calculating the
Fnet_x correctly. Is the above equation correct?
N = mgcos(O) =>
ax = 4.343 m/s/s
OOPS EDIT: The friction force should be down since the block is just about to slide UP!
Btw I meant by "x" an axis being horizontal.
But the mistake you are doing is to assume that the net force perpendicular to the plane is zero. This is the case when the incline is not accelerating. But it's not the case here because the net force along x is not zero. So you must do it a bit differently than you usually do it with inclined planes.
You must start by setting the net force along y to zero. so it will be (y component of N) - mg =0. From this you can solve for N. Then you go along x and find a_x.
Hope this helps.
I think I understand it now.
Thanks again!
Thanks again!
You are welcome.
Best luck!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
