Inconsistent underdetermined system
  • Thread starter Thread starter zcd
    System
An inconsistent underdetermined system consists of two equations with three unknowns, where the equations do not intersect, indicating no solution exists. The confusion arises from the definitions, as "inconsistent" implies no solutions while "underdetermined" suggests multiple solutions due to fewer equations than unknowns. Clarification indicates that underdetermined refers to having fewer equations than variables. An example provided is the intersection of two offset parallel planes, which illustrates the concept effectively. Understanding these definitions is crucial for solving such systems accurately.
zcd
Give an example of an inconsistent underdetermined system of two equations in three unknowns.
I'm confused as to what the question is asking for. Doesn't inconsistent mean that the system has no solution while underdetermined means the system has many solutions defined parametrically? The two definitions seem to contradict here.
i think in this context underdetermined means less equations than unknowns, and inconsistent, means there are no solutions
an example might be finding the intersection of two offset parallel planes?
that makes the problem much more doable. thanks :)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 30 ·
  • · Replies 21 ·
