Increased Density Results in Decreased speed of sound?
The speed of sound is described by the equation c=√(C/ρ), indicating that as density (ρ) increases, the speed of sound (c) decreases if the coefficient of stiffness (C) remains constant. This counterintuitive relationship arises because the stiffness of a medium, such as water, significantly affects sound transmission, as it resists compression more than air does. The bulk modulus, related to stiffness, explains why sound travels faster in water despite its higher density compared to air. The discussion highlights that the speed of sound is more influenced by the medium's ability to compress than by the number of particles present. Understanding these principles is essential for grasping acoustic wave propagation in various materials.
Da Apprentice
According to the equation c=√(C/ρ) where c is the speed of sound, C is the coefficient of stiffness and ρ is the density of the medium throughout which a sound is played the speed of sound should acctually decrease with an increase in density. Why is this so? I would've thought that increasing the amount of particles within a given area that sound can be transmitted along would result in the increased speed of the sound. I thought it was exactly due to the increased density of water in relation to ait that it transmitted sound faster. Is this formula wrong or am I reading it wrong? Also could someone please explain the coefficient of stiffness part of the equation and where this relates to the physical properties of a medium?
Thanks,
I am not the best to explain this, I work in applied work. The wave equation for acoustic wave propagation is derived from our understandings of stress and F=ma. What we are really talking about is very small disturbances in matter, as such the mass is an important factor but in the derivation of the wave propagation equation the volume cancels out leaving only the density.
The coefficient of stiffness is what would be called in seismic work the bulk modulus which is the resistance of a material to compression, at least in the acoustic case but not in the elastic case where it would be multiple moduli. Pretty much any book on geophysics should give you a good explanation of elastic wave propagation, sorry mine are all in storage.
Think of a simple harmonic oscillator (e.g., weight m dangling from a spring with constant k). Intuitively, what do you expect to happen to the oscillations if you increase the mass m (or more to the point, the ratio m/k)?
The formula is exactly right. The stiffness portion of the equation is the reason why water has a much higher speed of sound than air, not the density. The relevant stiffness for sound is compression, since sound is a compression wave. Think of how hard water is to compress compared to air. That is the reason why water has a very high sound speed. As oliver said, a good way to think about it is a simple mass spring system - if the mass is increased, and the spring is kept the same, the oscillations slow down.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
