Can indefinite integration be simplified using substitution?
The discussion focuses on simplifying indefinite integration using substitution, specifically the integral of 1/(x(1-x))^(1/2)dx. A substitution of x=t^2 is proposed, leading to an expression involving arcsin, but the book's answer differs. Participants explore the relationship between the two results, asserting that both answers can be equal after manipulation, despite differing constants. The conversation also highlights the importance of verifying integration results through differentiation and discusses the use of trigonometric identities to prove constant relationships. Ultimately, the integration process and verification methods are emphasized as key to understanding the problem.
Crystal037
Integrate 1/(x(1-x))^(1/2)dx
Integral of 1/rt(1-x^2)dx = arcsinx
Let x=t^2
Then dx=2t dt
Integral of 1/(x(1-x))^(1/2)dx
= integral of 2tdt/t(1-t^2) ^(1/2)
= integral of 2dt/(1-t^2) ^(1/2)
= 2 arcsin(t) +c
= 2 arcsin(rt(x)) +c.
But the answer in my book is arcsin(2x-1) +c.
Tell me how
2 arcsin(rt(x) +C= arcsin(2x-1) +c
I know the constant will vary for both the answers and both the answers must come equal after some manipulation. Is my answer correct.
Try to prove that ##2 arcsin(x)-arcsin(2x-1)## is a constant.
Just denote be ##y=arcsin x## and then ##2x-1 = 2\sin y -1##, so you need to show that the following is constant: ##2y-arcsin(2\sin y -1)##, if you denote this by ##u## you get: ##2y-u=arcsin(2\sin y -1)## which means that: ##\sin (2y-u) = 2\sin(y)-1##; from here you need to solve a trig equation like in high school.
I meant ##y = arcsin \sqrt{x}##.
Crystal037 said:
Homework Statement:: Integrate 1/(x(1-x))^(1/2)dx
Relevant Equations:: Integral of 1/rt(1-x^2)dx = arcsinx
Let x=t^2
Then dx=2t dt
= 2 arcsin(t) +c
Tell me how
One good thing about doing integration is that you can always check your answer by differentiating it to check you get back the integrand.
I don't understand, however, this variable ##r## that seems to come and go from one line to the next.
There is no variable r I used rt to denote root
Yeah I differentiated it and the answer is correct. Thank you
I am getting LHS as a function of cos2y and sin 2y while RHS only as a function of cos2y. Where am I getting wrong
Crystal037 said:
I am getting LHS as a function of cos2y and sin 2y while RHS only as a function of cos2y. Where am I getting wrong?
The quickest way must be to differentiate, surely? If the derivative is zero, then the function is a constant. And, setting ##x =0## will give you the constant.
Otherwise, you need the double angle formula.
For integrating, even more simple I think just substitution in original x = t + ½ .
Likes SammyS and archaic
Using a graphing calculator you can find that ##\displaystyle 2\arcsin(\sqrt{x}\ ) - \arcsin(2x-1) ## is ##\dfrac{\pi}{2} ## .
This suggests that ##\displaystyle 2\arcsin(\sqrt{x}\ ) - \dfrac{\pi}{2} = \arcsin(2x-1) ##.
Take the sine of the left hand side and you get ##2x-1##, after a bit of manipulation.
Your integral is:
$$\int \frac{1}{\sqrt{x(1-x)}} dx=\int\frac{1}{\sqrt x}\cdot\frac{1}{\sqrt{1-x}} dx$$
Doesn't ##\frac{1}{\sqrt x}## remind you of the derivative of some function? Don't you think that ##x=(\sqrt x)^2##?
Nice one!
  • · Replies 105 ·
