Indefinite trigonometric integral with an Nth Root
The discussion revolves around solving the integral ∫ sin(16x) √[a]{cos(16x)} dx, with the requirement that the answer be linear in the constant "a." An initial attempt at the solution involved a substitution that led to a result not meeting the linearity condition. Participants noted confusion over the requirement for linearity in "a" and the absence of a "+C" in the final answer, which is typically expected for indefinite integrals. Suggestions included checking the input format for the homework website, as it may misinterpret the answer. The conversation highlights the challenges of adhering to specific formatting requirements in online homework systems.
WalrusMunchies
Solve: \int sin(16x) \sqrt[a]{cos(16x)}\,dx Answer should be linear in the constant "a"
\int sin(16x) \sqrt[a]{cos(16x)}\,dx Set: u=cos(16x), du=-16sin(16x) du ~~\Rightarrow~~ {-1/16}\int \sqrt[a]{u}\,du = {-1/16}(\frac{1}{1+1/a}u^{1+{1/a}})+C = {-1/16}(\frac{1}{1+1/a}cos^{1+{1/a}}(16x))+C
This is what I did initially, then i realized it wasn't linear in the constant "a".
I have a feeling i may need to substitute a log function into make "a" a linear constant.
\int sin(16x) \sqrt[a]{cos(16x)}\,dx Set: u=cos(16x), du=-16sin(16x) du ~~\Rightarrow~~ {-1/16}\int \sqrt[a]{u}\,dx = {-1/16}(\frac{1}{1+1/a}u^{1+{1/a}})+C = {-1/16}(\frac{1}{1+1/a}cos^{1+{1/a}}(16x))+C
What you did is fine, except you mixed up some dx's and du's in the presentation. I have no idea what they mean by "Answer should be linear in the constant a". It's clearly not.
Thanks for the reply
The question initially doesn't say "Answer should be linear in the constant a", but my homework website doesn't accept "+C" in this question, and gives me that message as a response when i put in my answer.
Normally I would see my professor about this, but it is reading week.
Well, there should be a "+C" in the answer if it's an indefinite integral, and I think you did it correctly. Not sure what to say.
I can only think of two things. The site might require a more standard form after simplifying, and it's possible you inputted the answer incorrectly. How do you input your answers? Is it text based or is there a GUI for you to use?
For example, if you input cos^(1/2)(x) into WolframAlpha, it reads it as ##\sqrt{\cos{x}} \cdot x## where you might have wanted it to be intepretted as simply ##\sqrt{\cos{x}}##.
(I brought up this example because this is how you formatted your answer to the problem)
##\displaystyle \frac{1}{1+1/a} = \frac{a}{a+1} ##
Maybe the website would like this better.
Well, that's not "linear in a" either. Who knows what the website would like?
  • · Replies 105 ·
  • · Replies 22 ·
  • · Replies 27 ·
