Inelastic Collision: Kinetic Energy vs Momentum
The discussion centers on the relationship between kinetic energy and momentum in inelastic collisions, specifically when one object is initially at rest. Participants clarify that momentum is conserved, and the change in kinetic energy (ΔK) is defined as the difference between final and initial kinetic energy (Kf - Ki). It is established that there is no direct 1:1 relationship between momentum and kinetic energy, as different scenarios can yield the same momentum with varying kinetic energies. The confusion arises from mixing these two distinct physical concepts.
  • Understanding of inelastic collisions
  • Familiarity with the conservation of momentum
  • Knowledge of kinetic energy calculations
  • Basic algebra for manipulating equations
  • Study the principles of inelastic collisions in detail
  • Learn about the conservation of momentum and its applications
  • Explore kinetic energy formulas and their implications in collisions
  • Investigate scenarios demonstrating the relationship between momentum and kinetic energy
Physics students, educators, and anyone interested in understanding the dynamics of collisions and the interplay between momentum and kinetic energy.
xxphysics
In an inelastic collision is the change in kinetic energy equal to the difference of final and initial momentum if one of the objects is initially at rest? For example:
m1v = (m1+m2)Vf -----> 0 = (m1+m2)Vf - m1v1
1/2(m1+m2)Vf^2 - 1/2m1v^2 = (m1+m2)Vf - m1v1
Or totally wrong? Thanks!
Totally wrong. The units don't even match.
Momentum is conserved, so the difference between the initial and final momentum has to be zero. You've captured that when you wrote ##(m_1+m_2)v_f-m_1v_1=0## for the particular case in which ##m_2## starts at rest and the two masses stick together in the inelastic collision.
So when you ask whether the change in kinetic energy is equal to the difference between the initial and final momentum, you're asking whether the change in kinetic energy is equal to zero.
This would be a good time to stop and think about the definition of "inelastic collision".
OK, my take on this is that, this is a rather odd question. You're asking if
ΔK = Kf - Ki
This is odd because that is the DEFINITION of ΔK!
Zz.
This is not what the quoted sentence says. :)
I am aware that the OP is mixing momentum with kinetic energy. I was hoping that this was an oversight, and not out of ignorance.
Zz.
It's more than possible that he didn't actually know??
ΔK = Kf - Ki
Zz.
Zz
Zz.
Zz
Thank you :) I just thought they were both looking at the change in velocity and in both equations there is a way to account for the differences in mass (before and after collision) so I didn't think was absurd to wonder if there is a connection between the formulas.
ΔK = Kf - Ki
Zz.
No my question was if you could relate the momentum equation of an inelastic collision to the change in kinetic energy of that collision
I see what you are after. There isn't a 1:1 relationship between the two quantities. Particular circumstances will give particular relationships.
Two situations with the same total momentum and different KE transferred to the collision. For convenience I have chosen to bring the motion to a halt. :
Two equal masses m&m, traveling towards each other at v and -v (Earth frame of reference) will have a total momentum of zero and a total KE of mv2. Now reduce one of the masses to 0.1m and increase its velocity to 10v. Total momentum is still zero but the KE is (mv2 +0.1m(100v2))/2 = (1+10)mv2/2 =5.5mv2.
This two trivial cases are enough to show that your idea can't be relied on. It's the squaring of the velocity that upsets things.
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 18 ·
