MHB Can You Prove This Fraction Sequence is Less Than 1/1000?
The discussion centers on proving that the product of the fractions from 1/2 to 999999/1000000 is less than 1/1000. Participants share various methods, including induction, to approach the problem. The effectiveness of these methods is acknowledged, with specific praise for the induction technique. References to related threads and solutions are made to enhance understanding. The conversation emphasizes collaboration in finding a mathematical proof.
anemone
MHB
POTW Director
Show that $\dfrac{1}{2}\cdot\dfrac{3}{4}\cdot\dfrac{5}{6} \cdots\dfrac{999999}{1000000}<\dfrac{1}{1000}$
Mathematics news on Phys.org
We claim that
\frac{1 \cdot 3 \cdot 5 \cdots (2n-1)}{2 \cdot 4 \cdot 6\cdots (2n)} \leq \frac{1}{\sqrt{3n+1}}
for all positive integers n. The result then follows by setting n = 500000 and observing that
\frac{1}{\sqrt{1500001}} &lt; \frac{1}{1000}
The claim is proved by induction on n.
For n = 1, the claim is obvious.
Assume the claim is true for n. We have to show that
\frac{1 \cdot 3 \cdot 5 \cdots (2n-1)(2n+1)}{2 \cdot 4 \cdot 6\cdots (2n)(2n+2)} \leq \frac{1}{\sqrt{3n+4}}
But
\frac{1 \cdot 3 \cdot 5 \cdots (2n-1)(2n+1)}{2 \cdot 4 \cdot 6\cdots(2n)(2n+2)}=\frac{1 \cdot 3 \cdot 5 \cdots (2n-1)}{2 \cdot 4 \cdot 6\cdots (2n)} \frac{2n+1}{2n+2}\leq\frac{1}{\sqrt{3n+1}}\frac{2n+1}{2n+2}
So we have to show that
\frac{1}{\sqrt{3n+1}}\frac{2n+1}{2n+2}\leq \frac{1}{\sqrt{3n+4}}
This inequality follows by clearing fractions, squaring both sides and simplifying. The result is
19n \leq 20n
which holds for all positive n. This completes the proof of the claim.
As reported in...
http://mathhelpboards.com/questions-other-sites-52/unsolved-analysis-number-theory-other-sites-7479-4.html#post40097
... the the explicit expression of the sequence is...
$\displaystyle a_{n} = \prod_{k=1}^{n} (1 - \frac{1}{2\ k})\ (1)$
... and it is the solution of the difference equation...$\displaystyle a_{n+1} = a_{n}\ (1 - \frac{1}{2\ n}),\ a_{1}=1\ (2)$
The (2) is related to the ODE...
$\displaystyle y^{\ '} = - \frac{y}{2\ x}\ (3)$
... the solution of which is $\displaystyle y = \frac{c}{\sqrt{x}}$, so that we can suppose $\displaystyle a_{n} \sim r_{n}= \frac{c}{\sqrt{n}}$. If we suppose that $r_{500000}= \frac{1}{1000}$ then is $\displaystyle c = \frac{1}{\sqrt{2}}$. In the following table the first values os $a_{n}$ and $r_{n}$ are reported... $a_{1}= 1,\ r_{1} = .70710678...$
$a_{2}= .5,\ r_{2} = .5$
$a_{3}= .375,\ r_{3} = .40824829...$
$a_{4}= .3125,\ r_{4} = .35355339...$
$a_{5}= .273438...,\ r_{5} = .31627766...$
$a_{6}= .246094...,\ r_{6} = .2886751...$
$a_{7}= .225586...,\ r_{7} = .2672612...$
$a_{8}= .209473...,\ r_{8} = .25$
$a_{9}= .196381...,\ r_{9} = .2357022...$
$a_{10}= .185471...,\ r_{10} = .2236067...$
It is clear from the table that for n 'large enough' the relative increments of the $a_{n}$ and $r_{n}$ are pratically the same and that is verified considering that is... $\displaystyle \frac{a_{n+1}}{a_{n}} = 1 - \frac{1}{2\ n}$ $\displaystyle \frac{r_{n+1}}{r_{n}} = \sqrt{1 - \frac{1}{n}} = 1 - \frac{1}{2\ n} - \frac{1}{8\ n^{2}} - ...\ (4)$... so that we can conclude that is $\displaystyle a_{500000} < r_{500000} = \frac{1}{1000}$...
Kind regards
$\chi$ $\sigma$
Thanks for participating to both of you, Petek and chisigma! Your induction method looks nice and great, Petek!
@chisigma, your solution post reminds me of this thread(http://mathhelpboards.com/discrete-mathematics-set-theory-logic-15/find-a_%7B100000%7D-8448.html)! Bravo, chisigma!:)
Solution provided by other:
Let $x=\dfrac{1}{2}\cdot\dfrac{3}{4}\cdot\dfrac{5}{6} \cdots\dfrac{999999}{1000000}$.
Thus, what we need to show is that $x<\dfrac{1}{1000}$.
Now, note that
$x^2=\dfrac{1^2}{2^2}\cdot\dfrac{3^2}{4^2}\cdot \dfrac{5^2}{6^2} \cdots\dfrac{999999^2}{1000000^2}$
Since decreasing the denominator of a fraction makes it bigger, we have that
$\dfrac{1^2}{2^2}\le \dfrac{1^2}{2^2-1}= \dfrac{1^2}{(2-1)(2+1)}=\dfrac{1^2}{1\cdot3}$
$\dfrac{3^2}{4^2}\le \dfrac{3^2}{4^2-1}= \dfrac{3^2}{(4-1)(4+1)}=\dfrac{3^2}{3\cdot5}$
$\dfrac{5^2}{6^2}\le \dfrac{5^2}{6^2-1}= \dfrac{5^2}{(6-1)(6+1)}=\dfrac{5^2}{5\cdot7}$
$\vdots\;\;\;\;\;\;\;\;\;\;\;\vdots$
$\dfrac{999999^2}{1000000^2}\le \dfrac{999999^2}{1000000^2-1}= \dfrac{999999^2}{(1000000-1)(1000000+1)}=\dfrac{999999^2}{999999\cdot1000001}$
Multiplying all these together we get
$x^2<\dfrac{1}{1000001}<\dfrac{1}{1000000}$
Now, taking square roof of both sides we obtain
$x<\dfrac{1}{1000}$ or
$\dfrac{1}{2}\cdot\dfrac{3}{4}\cdot\dfrac{5}{6} \cdots\dfrac{999999}{1000000}<\dfrac{1}{1000}$ (Q.E.D.)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
