socialcoma
if a humming bird is hovering in a car going at a constant rate, and the car comes to a sudden stop, will the bird fly into the windsheild?
A hummingbird hovering in a car that suddenly stops will likely lurch forward but not necessarily collide with the windshield. The bird, while capable of rapid wing beats (20-30 times per second), rides the air within the vehicle, similar to a helium balloon. When the car brakes, the air in the car moves forward, creating a vacuum behind, which affects the bird's position. However, due to its agility and ability to make course corrections, the bird may not hit the windshield unless the braking force is extreme.
PREREQUISITESPhysics enthusiasts, biology students, and anyone interested in the dynamics of motion and flight mechanics will benefit from this discussion.
Do *YOU* fly toward the windshield when the car suddenly stops? (hint: why are you wearning a seatbelt?) There's your answer.Originally posted by socialcoma
The hummingbird isn't floating - its FLYING. Huge difference.when it is floating, it is staying in place in the "bubble" of air in the car...when the car brakes, in order for the hummingbird to hit the windshield, all that air would have to be smashed forward...which would leave a vacuum in the back and then that would be filled up...so wouldn't it get really windy in the car whenever u stop?
Buoyancy depends on the density of an object, not its mass. As the humming bird has a higher density than air but the helium balloon a lower density, they will not behave identically, i.e. the humming bird will fly against the windshield if you brake the car (unless it can react very quickly and brake as well).Originally posted by LURCH
I think not. Like the hellium balloon, the humming bird rides the air within the vehicle. Admittedly, the humming bird is less bouyant than the balloon, but it is also far less massive than a person
