Infinite Limit: How to Prove a Sequence Goes to Infinity
  • Thread starter Thread starter The_Iceflash
    Infinite Limit
7 replies · 3K views
The_Iceflash
Ok. For this sequence: [tex]a_{n} = n^2\left|cosn\pi\right|[/tex], Show/Prove that [tex]a_{n} \rightarrow\infty[/tex]
N/A
I have to manipulate the statement to show that
[tex]n^2\left|cosn\pi\right| > ?[/tex]
I'm having trouble making a statement that's smaller. If it was a fraction I could do it:
Ex: Manipulating [tex]\frac{n^3}{n^2+2}[/tex] gets
[tex]\frac{n^3}{n^2+2} > \frac{n^3}{n^2+n^2} = \frac{n^3}{2n^2} = \frac{n^3}{2}[/tex]
I replace 2 with n^2 to make the denominator bigger thus making it smaller. I somehow have to do something like that with the sequence given but I'm not sure how.
Any help is appreciated.
Mark44 said:
I think something is missing in the problem statement. What is the exact wording of this problem?
I just added it above.
Mark44 said:
Prove that it's greater than what? That still doesn't make any sense.
That's what I have to figure out. The example with the fraction I showed is what I have to do somehow.
Mark44 said:
Assuming n is an integer, |cos(n*pi)| = 1, so n2|cos(n*pi)| = n2. What does that do if n gets large?
If n gets large then the sequence gets large.
So, would n2|cos(n*pi)| > n|cos(n*pi)| be sufficient?
After I would do that I need to set it greater than M and solve for it.
For example: the fraction above I set [tex]\frac{n^{3}}{2} > M[/tex] and solved for n.
Then I'd put it all together formally.
Clearly, from the earlier work, [tex]\lim_{n \to \infty} a_n = \infty[/tex]
Now, to prove that this is so, you want for find a number M s.t., for all n >= M, an > M.
You have an = n2 (reason given earlier) and you want an > M.
Can you combine these and solve for n?
