Infinitesimal Mass & Distant Space: GR Effects
  • Thread starter Thread starter Blayde Keel
    Mass
Blayde Keel
In general relativity what happens when two masses approaching zero, are separated by a distance approaching infinity? Is there a condition in general relativity where a lack of mass can warp space-time up instead of a massive object putting a dent in it? I think I am asking what happens to GR in conditions opposite to those of a black hole.
I can see things better if I know what happens when values --> infinity vs values --> zero.
As the masses approach zero, the spacetime becomes flatter, gravitational effects become smaller, and things start to look more and more like empty space with no gravitating bodies anywhere.
Your mention of "a massive object putting a dent in [space-time]" suggests that you are thinking in terms of the very common picture showing a heavy object sitting on a sheet of elastic material, something like this: http://en.wikipedia.org/wiki/File:Spacetime_curvature.png
Try to put that picture out of your mind, as it is very misleading. If you search this forum for "rubber sheet" you'll find some discussion about why it is so misleading.
Thank you and I will look up the problems involved in the "rubber sheet" view of space-time.
I looked at the discussions about the "rubber sheet." I need to get another concept right. GR talks about flat space, quantum physics talks about the vacuum; both would be low mass but they are not the same thing, right?
Let me rephrase my last question, of course they are not the same, the whole universe operates in a vacuum; what I meant to ask was; would an area of space with mass --> zero affect the vacuum? In the great voids between the galaxies is the vacuum affected by the absence of matter?
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
