Influence of the sun on the temperature of the ocean
The forum discussion centers on an experiment investigating how sunlight influences water temperature, specifically using a bowl of water heated with a copper plate and sinusoidal current. Temperature sensors placed at varying depths revealed that sensor outputs showed decreasing amplitudes and increasing phase shifts with depth. Participants debated the applicability of these findings to deeper ocean layers, noting that sunlight penetration is limited to about 200 meters, which affects heat conduction and absorption. The discussion concluded that while the sun does heat the ocean, the vastness of the ocean makes solar cycle variations negligible in overall temperature changes.
  • Understanding of heat conduction principles
  • Knowledge of oceanography, specifically light penetration in seawater
  • Familiarity with temperature measurement techniques
  • Basic concepts of density variations in seawater
  • Research the effects of solar radiation on ocean temperature profiles
  • Explore the impact of salinity on seawater density and temperature
  • Study the limitations of light penetration in various water bodies
  • Investigate the role of convection in ocean temperature distribution
Oceanographers, environmental scientists, educators, and students interested in the thermal dynamics of ocean water and the influence of solar energy on aquatic environments.
Shukie
We did an experiment to find out how water is heated as a result of sunlight. We had a bowl of water which we heated with a copper plate on the water surface, through which we sent a sinusoidal current. We didn't use a lamp, because water doesn't absorb visible light very well and since our bowl is not very deep, the effect wouldn't be as pronounced with a lamp.
In the bowl we had a number of temperature sensors at varying depths. We found that, with increasing depth, the output of the sensors had decreasing amplitudes and increasing phase shifts:
http://img15.imageshack.us/img15/1381/wstr3.png
We are now looking for a real world example where this effect occurs as well. Our teacher said the deeper layers of the ocean might be applicable, because convection won't be a factor there (we only want to see how the sunlight heats the water) and the water doesn't move much. If you put a number of temperature sensors in a deeper layer of the ocean, would you get a similar result as the one in the above graph?
The temperature of the ground exhibits the same behaviour as well.
Water is a bad example, because it is at its most dense at about 4C.
I'm afraid that your teacher forgot that light rarely penetrates ocean water deeper than 200 meters (656 feet).
http://oceanservice.noaa.gov/facts/light_travel.html
I thought, based on the experiment outlined in the OP, that he was more interested in heat conduction than direct absorption.
Yeah, but he said "we only want to see how the sunlight heats the water". The teacher said "the deeper layers of the ocean".
His thread title says 'Influence of the sun on the temperature of the ocean".
But I could be wrong. :biggrin: It won't be the first time.
This is only true of fresh water.
Seawater does not exhibit this anomalous behaviour.
Obviously the sun heats the ocean, but it's so large that solar cycle variations in the suns output are not noticeable in the bulk temperature of the ocean.
Keep in mind that the temperature of an object is a function of both input vs output.
So, if the heat loss of the ocean were reduced, it's temperature would rise.
Convection will eventually mix surface warming towards the depths, but the time scale for that is immense.
As an aside, sea water reaches it's maximum density near it's freezing point, which would be about -2C. However, salinity differances within the ocean are significant
I'm with NeoDevin. The nonpenetration of sunlight is the reason why the OP's experiment is relevant to the manner in which the sun would be expected to influence the temperature of deeper layers of the ocean.
That is a surprise! :smile:
  • · Replies 28 ·
  • · Replies 53 ·
13K
  • · Replies 20 ·
9K
26K
  • · Replies 33 ·
19K
