Initially evacuated chamber and maximum theoretical work
The discussion revolves around a problem involving an initially evacuated chamber and the calculation of maximum theoretical work in a thermodynamic context. Participants explore the implications of adiabatic processes, pressure-volume relationships, and the complexities introduced by the system's configuration, including the presence of a vacuum and the interaction between two tanks.
  • Homework-related
  • Some participants suggest that the process is adiabatic, noting that in such a process, PV is not constant, but there exists a relationship pV^k = C.
  • There is uncertainty regarding the nature of the process and whether it can be treated as isobaric, adiabatic, isothermal, or isometric.
  • One participant expresses concern about the irreversibility associated with introducing the exit stream from a turbine into a vacuum tank, suggesting that this complicates the problem.
  • Another participant questions the assumption that the turbine can maintain equal temperatures in both tanks during the process, indicating that this may not be realistic.
  • There are discussions about the correct use of absolute versus gauge pressure in calculations, with some participants emphasizing the importance of using absolute pressure for accurate results.
  • Participants debate the final volume needed for calculations, clarifying that it should be the combined volume of both tanks rather than just one.
  • One participant proposes an alternative approach by considering a small initial pressure in the second tank instead of a vacuum, suggesting this might simplify the analysis.
Participants generally agree that the problem is complex and that the process is adiabatic. However, there are multiple competing views regarding the assumptions made about temperature equality in the tanks and the treatment of pressures, indicating that the discussion remains unresolved.
Participants highlight limitations in their assumptions, particularly regarding the ideal behavior of the turbine and the irreversibility of the process. There is also a noted dependence on definitions of pressure types and the specific conditions of the system.
Stephen Miller
Energy Balance Equation
Given: V_1 = 10 L, V_2 = 22 L
Not sure what I need to do here. We are told to ignore heat transfer, and the problem suggests that this is not a steady-state problem. The gage pressure is given, so I think that means we need to calculate for the absolute pressure, which would be 997 kPa. Cp and k are given, which yields Cv = 0.717.
I was thinking to use the fact that we have two volumes and the absolute pressure, so use the definition of work and compute that integral. However, the problem isn't that simple. Maybe we need to take a control volume about the entire system? Not sure, please help.
Stephen Miller said:
Homework Statement: Initially evacuated chamber and maximum theoretical work
Homework Equations: Energy Balance Equation
The first step is to determine which type of process this is (eg., isobaric, adiabatic, isothermal, isometric, etc.)
(There may be an integral involved later, but first things first.)
It's adiabatic
It's adiabatic
Correct! :smile:
In an adiabatic process, [itex]PV \ne[/itex] constant.
But there is a pressure and volume relationship that is equal to a constant (in an adiabatic process). Can you tell me what that relationship that is?
Is it pV^n = constant ?
Correct again. :smile:
Except I think your coursework might use the variable [itex]k[/itex] instead of [itex]n[/itex]. I think. At least that's what I interpret in the problem statement when it says, "[itex]k = 1.4[/itex]."
So
[itex]pV^k = C[/itex]
where [itex]C[/itex] is a constant.
Solve for [itex]p[/itex] in terms of [itex]C[/itex] and [itex]V^k[/itex].
Then you can plug that into [itex]W = \int_{V_1}^{V_{1+2}} pdV[/itex] and voilà.
[Edit: Maybe "[itex]C[/itex]" wasn't the best choice of variable name here. Call it [itex]K[/itex] if you'd rather. Just don't confuse it with [itex]c_p[/itex] or [itex]c_v[/itex]. They're all different constants. ... No, [itex]K[/itex] would be a bad choice too (your coursework uses [itex]k[/itex] for something else). How about [itex]C_{\mathrm{konstant}}[/itex]. ?:)]
It seems to me this is a pretty complicated problem. I've been thinking about it for a few hours, and I still don't see how to proceed. The main difficulty seems to me to be that tank that initially has vacuum in it. I would expect there to be some irreversibility associated with introducing the exit stream from the the turbine, and the mixing of the exit stream from the turbine with the existing contents of the tank at any time during the process.
It is clear that, in the end, the final pressures in the two tanks are going to be equal. But it also seems that the temperatures in the two tanks at the end of the process do not have to be equal.
I'll keep thinking about how to proceed.
My previously suggested approach does make a few assumptions. Primarily, it assumes that the turbine is somehow able to keep the gas in both tanks at equal temperatures [extracting any available work in the process]. Even if the temperature changes over time, the turbine is able to maintain equal temperatures in both tanks at any given time.
That assumption of mine is probably not very realistic. But hey, the creator if the problem did find a tank of ideal gas, so why not an ideal turbine? (Great yard-sale find! 😄 )
[Edit: This heat transfer is not wasted in this ideal turbine. Any temperature differential between the two tanks is utilized as part of the work extraction.]
I don't know how to use LaTex, so here's an attached file instead :)
I hope that's right. I got a positive answer for W, which matches with W_out.
The final volume is not just the volume of tank-2, but rather the volume of tank-1 plus the volume of tank-2.
Is the volume of tank-2 12 liters or 22 liters? If it's 12 liters, then nevermind.
Also, in your final step you used the gauge pressure instead of absolute pressure for [itex]p_1[/itex].
##V_2 = 22 L##
##V_2 = 22 L##
Is that the volume of tank-2 or the combined volume of tank-1 and tank-2?
The final volume for this exercise needs to be the combined volume.
That's the volume for tank 2
OK, then you'll need to re-do the calculations such that the final volume is the combined volume. Also, don't forget to use absolute pressures (instead of gauge pressure).
That said, your approach (equations and whatnot) look good! :smile:
So change the upper bound of my integral to ##V_2 = 32## and use ##997 kPa## instead of ##896 kPa##
Yep. I think that should do it.
Thank you for your help, I'll have to swing by my teacher's office hours to check my work.
In my judgment, you guys are significantly underestimating the complexity of this problem.
I don't see how the two tank temperatures can be at the same in the setup given (since the two tanks are physically separated). Any adiabatic reversible turbine is going to feature a decrease in both temperature and pressure.
I think I can solve this if I assume that, rather than a vacuum, there is some small initial pressure (and associated mass) within the 2nd tank. Maybe then I can examine the solution to see if it has a limit as the initial pressure approaches zero. It may take me some time to analyze this problem in this way.
I agree that if the yard-sale turbine (great find, though it may be) does not have components that allow it to operate as a heat engine (capitalizing on temperature differences) in conjunction with it operating on the pressure differences, then this problem becomes much harder than we've treated it thus far.
collinsmark said:
I agree that if the yard-sale turbine (great find, though it may be) does not have components that allow it to operate as a heat engine (capitalizing on temperature differences) in conjugation with it operating on the pressure differences, then this problem becomes much harder than we've treated it thus far.
That does give me an idea though. If we can calculate the amount of work specifically obtained from keeping the two tanks at equal temperatures, we could then subtract that off the original answer, and that should be the answer for a turbine that does not attempt to keep the tanks at equal temperatures! (I'm not 100% sure on that, however.)
Hmm. Easier said than done though. 🤔
Here is my analysis of the problem based on the open system (control volume) versions of the 1st and 2nd laws of thermodynamics applied to each of the two tanks and the turbine. It does not require the temperatures in the two tanks to be equal (as I definitely do not expect them to be). It also assumes that the mass holdup in the turbine is negligible, so that the turbine operates at quasi-steady-state, and all the mass of gas resides in the two tanks.
Nomenclature
##n_1(t)=## moles of gas in tank 1
##n_2(t)=## moles of gas in tank 2
##T_1(t)=## temperature of gas in tank 1 = temperature of gas entering turbine
##T_2(t)=## temperature of gas in tank 2 (assumed well-mixed)
##P_1(t)=## pressure of gas in tank 1 = pressure of gas entering turbine
##P_2(t)=## pressure of gas in tank 2 = pressure of gas exiting turbine
##T_f(t)=## temperature of gas exiting turbine and entering tank 2
##u_1(t)## = internal energy per mole of gas in tank 1 = internal energy per mole of gas exiting tank 1 and entering turbine
##h_1(t)## = enthalpy per mole of gas in tank 1 = enthalpy per mole of gas exiting tank 1 and entering turbine
##h_f(t)## = enthalpy per mole of gas exiting turbine and entering tank 2
##u_2(t)## = internal energy per mole of gas in tank 2
TANK 1
Application of the open system version of the 1st law to Tank 1 yields:
$$\frac{d(n_1u_1)}{dt}=\frac{dn_1}{dt}h_1=\frac{dn_1}{dt}(u_1+RT_1)$$
Differentiating the left hand side by parts then yields:
$$n_1\frac{du_1}{dt}=RT_1\frac{dn_1}{dt}$$or equivalently $$n_1C_v\frac{dT_1}{dn_1}=RT_1$$ This equation integrates immediately to $$\frac{T_1}{T_{10}}=\left(\frac{n_1}{n_{10}}\right)^{(\gamma-1)}\tag{1}$$
The corresponding pressure is $$P_1=\frac{n_1RT_1}{V_1}=\frac{n_1RT_{10}}{V_1}\left(\frac{n_1}{n_{10}}\right)^{(\gamma-1)}=\frac{n_{10}RT_{10}}{V_1}\left(\frac{n_1}{n_{10}}\right)^{\gamma}=P_{10}\left(\frac{n_1}{n_{10}}\right)^{\gamma}\tag{2}$$
Eqns. 1 and 2 express the temperature in Tank 1 parametrically in terms of the number of moles of gas ##n_1(t)## remaining in the tank at any time. As expected, both the temperature and pressure decrease as gas leaves the adiabatic tank during the process.
TURBINE
Application of the open system version of the 2nd law of thermodynamics to the Turbine operating at steady state, adiabatically, and reversibly yields: $$-\frac{dn_1}{dt}\Delta s=0$$ where ##\Delta s## is the change in entropy per mole of gas passing through the turbine, given by:
$$\Delta s=C_p\ln{(T_f/T_1)}-R\ln{(P_2/P_1)}=0$$or equivalently$$\frac{T_f}{T_1}=\left(\frac{P_2}{P_1}\right)^{\frac{(\gamma-1)}{\gamma}}\tag{3}$$where ##P_2## is the exit pressure from the turbine (also equal to the pressure in Tank 2)
TANK 2
Application of the open system version of the 1st law to Tank 2 yields:
$$\frac{d(n_2u_2)}{dt}=\frac{dn_2}{dt}h_f=\frac{dn_2}{dt}(u_f+RT_f)$$
$$n_2\frac{du_2}{dt}=(u_f-u_2+RT_f)\frac{dn_2}{dt}$$or equivalently
$$n_2C_v\frac{dT_2}{dt}=(C_pT_f-C_vT_2)\frac{dn_2}{dt}$$or equivalently
$$\frac{d{(n_2T_2)}}{dn_2}=\gamma T_f$$
Next, from the ideal gas law, we have that ##n_2T_2=\frac{P_2V_2}{R}##. Substitution of this into the previous equation gives:$$\frac{V_2}{R}\frac{dP_2}{dn_2}=\gamma T_f\tag{4}$$
If we next substitute Eqns 1- 3 into Eqn. 4, we obtain
$$\frac{V_2}{R}\frac{dP_2}{dn_2}=\gamma T_{10}\left(\frac{P_2}{P_{10}}\right)^{\frac{(\gamma-1)}{\gamma}}$$Further manipulation using the ideal gas law and integration leads to the astonishingly and unexpectedly simple result that $$\frac{P_2}{P_{10}}=\left(\frac{n_2V_1}{n_{10}V_2}\right)^\gamma\tag{5}$$
It will complete this analysis in a subsequent post.
I am not sure why one couldn't simply use the change in entropy formula considering the gas as the system undergoing a process from state 1 to 2 - with the turbine volume negligible. If so, then we have
##\Delta S = \int_{1}^{2} \frac{\delta Q}{T} + \sigma##
Since there is no heat transfer the integral is zero. If we are looking for the maximum theoretical work then the entropy generation term is also zero. So
##\Delta S = 0##
If this is correct, then we can use, for an ideal gas,
##\Delta S = 0 = c_v ln(\frac{T_2}{T_1}) -R Ln(\frac{V_1}{V_2}) ##
This means that we can use the relation
##\frac{T_2}{T_1} = (\frac{V_1}{V_2})^{(k-1)}##
So if we plug in numbers we find ##T_2 = 187.2K##. Then we can use the 1st Law for a system
##\Delta U = Q-W = 0 - W \rightarrow \Delta U= -W##
Now use the ideal gas relation for the change in internal energy,
##\Delta U = c_v \Delta T##
Finally, this results in
##c_v(T_2 - T_1) = -79.6 kJ = -W##
so the maximum theoretical work is ##W_{max} = 79.6 kJ##.
mfig said:
I am not sure why one couldn't simply use the change in entropy formula considering the gas as the system undergoing a process from state 1 to 2. If so, then we have
The entropy generation is zero only if the process is reversible. And the discharge and mixing of the expanded gas from the turbine with the gas already in tank 2 during the process is going to be irreversible.
Right. But if we are looking for the maximum theoretical work, we should consider all processes reversible. Of course this is never achievable, but this would establish an upper limit. So it seems to me.
The problem statement clearly says that the only equipment available are the 2 tanks and the turbine. We must come as close as possible to reversible within this constraint.
I assumed no other equipment than the tanks and turbine, so I am confused about why you would point this out. "As close as possible to reversible" is very near reversible. I assumed exactly reversible, which puts an upper limit on the "very near" part.
What am I missing?
This is a continuation of the analysis presented in post #22. At the final state of this system, we must have that ##P_2## determined from Eqn. 5 is equal to ##P_1## determined from Eqn. 2. From this, it follows that $$\frac{n_2V_1}{n_{10}V_2}=\frac{n_1}{n_{10}}$$or equivalently: $$\frac{n_2}{n_1}=\frac{V_2}{V_1}$$So, amazingly, the final numbers of moles in each of the two tanks is just proportional to the tank volume. From this (and previous equations), it follows that, in the final state of the system, $$n_1=n_{10}\frac{V_1}{(V_1+V_2)}$$
$$n_2=n_{10}\frac{V_2}{(V_1+V_2)}$$
$$T_1=T_{10}\left(\frac{V_1}{V_1+V_2}\right)^{(\gamma-1)}$$
$$T_2=T_1=T_{10}\left(\frac{V_1}{V_1+V_2}\right)^{(\gamma-1)}$$
Now, for the parameters in this problem, $$n_{10}=\frac{(997000)(0.010)}{(8.314)(298)}=4.024\ moles$$
So, in the final state of the system, $$n_1=4.024(10/32)=1.258\ moles$$
$$n_2=4.024(22/32)=2.767\ moles$$
$$T_1=298\left(\frac{10}{32}\right)^{0.4}=187.1K$$
$$T_2=298\left(\frac{10}{32}\right)^{0.4}=187.1K$$
The change in internal energy for the system between the initial and final states is given by:
$$\Delta U=n_{10}C_v(T_1-T_{10})=(4.024)(20.79)(187.1-298)=-9278\ J$$
This is minus the maximum amount of work, so the maximum amount of work is +9278 J.
For the final pressure, I get 197 kPa
What am I missing?
I don't know. Have you looked over my analysis? Does anything look incorrect about that?
No, for your analysis is very detailed! One thing I notice is that the pressures aren't equal at the end, unless I have misapplied your results? (Perhaps this is round-off error.)
##P_1=P_{10}\left(\frac{n_1}{n_{10}}\right)^{\gamma}=997 \left(\frac{1.258 }{4.024 }\right)^{1.4}=195.7kPa##
##P_2=P_{10}\left(\frac{n_2V_1}{n_{10}V_2}\right)^\gamma = 997\left(\frac{2.676 *10}{4.024 *22}\right)^{1.4}=186.8kPa##
Also, the ideal gas law is not satisfied in tank 2, if the pressure above is correct (but it is satisfied in tank 1 given the above pressure).
For tank 1:
##P_1 = n_1*R*T_1/V_1 =1.258*8.314*187.1/.01 = 195.7kPa##
This is as above.
But for tank 2:
##P_2 = n_2*R*T_2/V_2 = 2.676*8.314*256.5/0.022 = 259.4kPa##
This differs significantly from above.
  • · Replies 26 ·
