Input/Output Voltage Class C RF Amp
shawisco
Hi all:
I am a new member here with my first post. I am an adult learner trying to self-teach RF electronics. I have been working through David Rutledge's Electronics of Radio, while building the NorCal 40A transceiver.
I am getting caught up on understanding the Class C RF power amplifier circuit.
I don't understand how the output voltage across the collector of Q7 can be more than twice the DC supply voltage (12VDC). I assume that the reactive components--such as RFC1--are storing energy?
Any help would be appreciated. I have included the schematic below.
Schematic of a class C RF power amplifier stage labeled PA, with transistor Q7, zener diode D12 (1N4755A, 43V), RFC1 18uH choke, C44 0.047 coupling capacitor, and a low-pass filter with L7, L8, C45 330, C46 820, C47 330 feeding antenna jack J1; power input J2 10 to 15VDC through S1 Power and D7 1N5817.
hi there and welcome to PF
I cannot answer this completely
1) interesting circuit, its pretty standard except for the zener diode across the transistor ... never seen that before
2) consider that the 43V rating of the zener is just the voltage rating of the zener for when it will go into conduction and NOT the voltage that is
present across the transistor all the time and most likely none of the time
3) on the collector of the transistor, there is going to be an RF voltage as well as the DC supply voltage ... am not good enough to explain the complexities there
4) RFC1 is a choke, whose sole purpose is to isolate the DC rail from the RF voltage at the transistor collector ... We DO NOT want RF getting onto the DC rail, it will cause all sorts of bad things to happen
Dave
Some comments:
  • The purpose of D7 is to protect the power supply
  • When S1 breaks the connection to the power supply, it causes a voltage spike across RFC1. The Zener is there to protect Q7 when that happens.
  • If the antenna is disconnected, the load on Q7 changes drastically. The Zener may help protecting Q7 in that case.
A Class C amplifier is working somewhat like a switch. When a current flowing in an inductor is broken, a high voltage can be generated equal to -L dI/dt. This is where the voltage comes from, and you are correct that it comes from energy stored in the tank circuit. The Zener is used to limit the RF voltage across the transistor to a safe value. Dangerous voltage could arise if the load resistance is accidentally omitted or the load is severely mismatched.
