MHB Integer Find x,y for $y^2+2y=x^4+20x^3+104x^2+40x+2003$
  • Thread starter Thread starter kaliprasad
    Integer
kaliprasad
MHB
Find all solutions in integers $x,y$ of the equation $y^2+2y= x^4+20x^3+104x^2 + 40x + 2003$
Mathematics news on Phys.org
kaliprasad said:
Find all solutions in integers $x,y$ of the equation $y^2+2y= x^4+20x^3+104x^2 + 40x + 2003-----(1)$
let $p=x^2+10x=x(x+10)-----(2)$
from (1) we have :$y(y+2)=p^2+4p+2003$
$\therefore (y+1)^2=p^2+4p+2004---(3)$
from $(2):x^2+10x-p=0---(4)$
for $x,y$ both are intgers we get :$p>0,$ and $p$ may take values from the following lists:
$11(1\times 11),24(2\times 12),39(3\times 13),----,119(7\times 17)----,n\times (n+10)$
from $(3) : p^2+4p+2004$ is a perfect square
we may assume $p^2+4p+2004=(p+10)^2\rightarrow p=119$
hence $(x,y)=(7,128) \, (7,-130)$
or $(x,y)=(-17,128) \, (-17,-130)$
Though the ans is right but
is a weak assumption and some solutions could have been missing
in fact we can set:$p^2+4p+2004=(p+k)^2$
here $k$ must be even and $2< k \leq 44$, and $p=n(n+10), n\geq 1$
and we obtain :$p=n(n+10)=\dfrac {2004-k^2}{2k-4}---(*)$
the only solution for $(*)$ is $k=10, p=119$
My solution
Add 1 to both sides to get
$(y+1)^2 = x^4+20x^3+104x^2+40x+2004 = x^4+20x^3+ 104x^2+40x+ 4 + 2000 = (x^2+10x+2)^2 +2000$
or $(y+1)^2 - (x^2+10x+2)^2 = 2000$
for the above to have solution we need to have $(y+1)$ and $(x^2+10x+2)$ both should be even or odd and as $(x^2+10x+2) = (x+5)^2-23$ so
the $2^{nd}$ number with need to be 23 less than a perfect square.
so let us find (t,z) which are $(\pm501,\pm499),(\pm252,\pm248),(\pm129,\pm121),(\pm105,\pm95),(\pm60,\pm40),(\pm45,\pm5)$ out of which
only z = 121 which 23 less than is a perfect square
so we get
$y+1= \pm 129, (x+5) = \pm 12$ giving 4 solutions ($y=-130, x = - 17$), ($y= -130,x= 7$), ($y=128,x=7$),($y= 128, x= -17$)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
