How to Integrate e^x / (1+x^2) with Complex Contour Integration?
In summary, the integral of e^x / (1+x^2) is a complex integral that cannot be expressed in terms of elementary functions and requires advanced techniques to solve. It can be solved using numerical methods on a computer or calculator, but the exact solution cannot be obtained. This integral is significant in mathematics as it is used in various applications and is also a fundamental integral in the study of complex analysis. It has real-world applications in calculating areas under curves, studying damping in oscillatory systems, and calculating electric fields in physics.
Einsling
Hi
Could you please tell me how to integrate it? Thanks ~~
[tex]\int_{-\infty}^{\infty} \frac {e^{i\omega t}} {1+\frac{t^2}{\tau^2}} dt[/tex]
where i is imaginary unit, [tex]\omega, \tau[/tex] are positive real,
Complex contour integration should be good. Are you familiar with the residue theorem from complex variables?
1. What is the integral of e^x / (1+x^2)?
The integral of e^x / (1+x^2) is a complex integral that cannot be expressed in terms of elementary functions. It can be solved using techniques such as substitution or integration by parts.
2. Is there a shortcut or formula for solving this integral?
No, there is no simple formula for solving this integral. It requires advanced techniques and manipulation to obtain a solution.
3. Can this integral be solved using a computer or calculator?
Yes, this integral can be solved using numerical methods on a computer or calculator. However, the exact solution cannot be obtained as it involves infinite series.
4. What is the significance of this integral in mathematics?
The integral of e^x / (1+x^2) is an important integral in calculus and is used in various applications such as probability, physics, and engineering. It is also a fundamental integral in the study of complex analysis.
5. Are there any real-world applications of this integral?
Yes, this integral has many real-world applications, such as in the calculation of areas under curves, in the study of damping in oscillatory systems, and in the calculation of electric fields in physics.
  • Calculus
