Integral(s) involving differential equations or contour integration
4 replies · 3K views
Hello, all:
I have a few questions concerning a definite integral where I am meeting with limited success. The most important problem concerns:
[tex]\int_{0}^{\infty}\frac{\cos{x}}{x^2+1}dx[/tex]
Contour integration always has been my last resort, but differentiating under the integral sign, I soon found that some of the conditions were violated and simply could not find the right parameterization so that they held.
Relevant equations:
Naturally the residue theorem in complex analysis. I don't really have anything else...
The attempt at a (wrong) solution:
I attack the doubly improper integral over the entire real line (this will give me twice the integral because the integrand is an even function).
I note that there are no branch cuts and that poles exist at i and -i, so I construct the usual semicircular contour and evaluate the integral:
[tex]\oint_{C}\frac{\cos{z}}{z^2+1}dz=\int_{-r}^{r}\frac{\cos{x}}{x^2+1}dx+\int_{0}^{\pi}\frac{\cos{re^{ix}}}{{r^2}e^{2ix}+1}ire^{ix}dx[/tex]
In both cases I take the limit as r goes to infinity. In big-O notation:
[tex]\frac{\cos{re^{ix}}}{{r^2}e^{2ix}+1}ire^{ix}\in \frac{O(r)}{O(r^2)}[/tex]
Which goes to zero as r goes to infinity, so the second integral goes to zero.
Therefore:
[tex]\oint_{C}\frac{\cos{z}}{z^2+1}dz=\int_{-\infty}^{\infty}\frac{\cos{x}}{x^2+1}dx[/tex]
[tex]\frac{1}{2}\oint_{C}\frac{\cos{z}}{z^2+1}dz=\int_{0}^{\infty}\frac{\cos{x}}{x^2+1}dx[/tex]
Then I calculate the complex residue of i (the only pole enclosed in the contour). Since this is a simple pole of a ratio of two functions f(z)=cos(z) and g(z)=(z^2+1), the residue at i is:
[tex]\frac{f(i)}{g'(i)}=\frac{\cos{i}}{2i}=\frac{\cosh{1}}{2i}=\frac{e+e^{-1}}{4i}[/tex]
The residue theorem tells me that [itex]2i\pi[/itex] times the sum of the residues gives me the value of the closed contour integral, so I have:
[tex]\oint_{C}\frac{\cos{z}}{z^2+1}dz=2i\pi\frac{e+e^{-1}}{4i}=\frac{\pi}{2}(e+e^{-1})[/tex]
By the transitive property, this shows that:
[tex]\int_{0}^{\infty}\frac{\cos{x}}{x^2+1}dx=\frac{\pi}{4}(e+e^{-1})[/tex]
When I did the contour integration I must have done something wrong because http://www.wolframalpha.com/input/?i=integrate+cos[x]/[x^2+1]+from+0+to+infinity" gave me this:
[tex]\int_{0}^{\infty}\frac{\cos{x}}{x^2+1}=\frac{\pi}{2e}[/tex]
My question is this: what did I do wrong? Also, is there a clever t-parameterization I can use which doesn't violate the conditions of differentiation under the integral sign? If there is a method to subdue this integral outside of contour integration, I would be pleased to know: a series expansion, differentiation under the integral sign (I presume this would require a differential equation solution, as e appears in the result)...
All help is appreciated, as always.
QM
{?} said:
Hello, all:
Relevant equations:
Therefore:
[tex]\oint_{C}\frac{\cos{z}}{z^2+1}dz=\int_{-infty}^{\infty}\frac{\cos{x}}{x^2+1}dx[/tex]
[tex]\int_{-infty}^{\infty}\frac{\cos{x}}{x^2+1}dx=\frac{\pi}{4}(e+e^{-1})[/tex]
QM
Fixed LaTeX. You have to use / in the [ /tex] brackets, not \.
Thanks, micromass. I'm completely new to this LaTeX equation thing...I've been on Math Equation Object for so long now...
{?} said:
In big-O notation:
This is where your mistake lies. You have [itex]\cos(re^{ix})[/itex], but this is the complex cosine and it can grow exponentially large! I.e. you don't have [itex]|\cos(re^{ix})|\leq 1[/itex] anymore.
In general, this method won't work because the second integral does not go to 0.
What to do then? Well, it turns out that we can consider (with C being the semicircular contour):
[tex]\int_{C}{\frac{e^{iz}dz}{z^2+1}}[/tex]
This can be split up into two integrals, and in this case, the second integral will go to 0. So we have
[tex]\int_{C}{\frac{e^{iz}dz}{z^2+1}}\rightarrow \int_{-\infty}^{+\infty}{\frac{e^{ix}dx}{x^2+1}}[/tex]
And your integral can be found as the real part of this.
Ahh! Thanks, that does make sense now. In my haste such a simple observation eluded me! You can see clearly why I am not cut out for contour integration. I will attack the problem with this new integrand now.
Thanks again,
QM
