Integral using trig substitution
5 replies · 2K views
tmt1
I have this integral:
$$\int_{}^{}\frac{1}{x^2 - 9} \,dx$$
I believe I can use trig substitution with this so I can set $x = 3 sec\theta$
Evaluating this, I get
$$ln|\csc\left({\theta}\right) - \cot\left({\theta}\right)| + C$$
Since $x^2 - 9 = 9sec^2\theta - 9$, then $\frac{x^2 - 9}{3} = tan^2\theta$ and $tan\theta = \sqrt{\frac{x^2 - 9}{3}}$.
Then we know $csc\theta = \frac{sec\theta}{tan\theta}$ and in this context $sec\theta = x / 3$, so $csc\theta = \frac{x / 3}{ \sqrt{\frac{x^2 - 9}{3}}}$.
Thus the answer is
$$ln| \frac{x / 3}{ \sqrt{\frac{x^2 - 9}{3}}} - \sqrt{\frac{3}{x^2 - 9}}| + C$$
Is this correct?
You can avoid a trig sub:
$$\int\dfrac{1}{x^2-9}\,dx=\dfrac16\int\left(\dfrac{1}{x-3}-\dfrac{1}{x+3}\right)\,dx=\dfrac16\left(\ln|x-3|-\ln|x+3|\right)+C$$
$$=\dfrac16\ln\left|\dfrac{x-3}{x+3}\right|+C$$
[tex]\int \frac{dx}{x^2-9}[/tex]
Let [tex]x \,=\,3\sec\theta \quad\Rightarrow\quad dx \;=\; 3\sec\theta\tan\theta\,d\theta[/tex]
[tex]x^2-9 \:=\:9\sec^2\theta-9 \;=\;9(\sec^2\theta-1) \;=\;9\tan^2\theta[/tex]
[tex]\text{Substitute: }\;\int\frac{3\sec\theta\tan\theta\,d\theta}{9\tan^2\theta} \;=\;\tfrac{1}{3}\int\frac{\sec\theta}{\tan\theta}d\theta \;=\;\tfrac{1}{3}\int\frac{d\theta}{\sin\theta}[/tex]
. . [tex]=\;\tfrac{1}{3}\int\csc\theta\,d\theta \;=\;\tfrac{1}{3}\ln|\csc\theta - \cot\theta| + C[/tex]Back-substitute: .[tex]\sec\theta \:=\:\frac{x}{3} \quad\Rightarrow\quad \csc\theta \:=\:\frac{x}{\sqrt{x^2-9}} \quad\Rightarrow\quad \cot\theta \:=\:\frac{3}{\sqrt{x^2-9}}[/tex]
We have: . [tex]\tfrac{1}{3}\ln \left|\frac{x}{\sqrt{x^2-9}} - \frac{3}{\sqrt{x^2-9}}\right| + C <br /> \;=\;\tfrac{1}{3}\ln\left|\frac{x-3}{\sqrt{x^2-9}}\right| +C[/tex]
. . [tex]=\;\tfrac{1}{3}\ln\left|\frac{x-3}{\sqrt{(x-3)(x+3)}}\right| + C \;=\;\tfrac{1}{3}\ln\left|\frac{\sqrt{x-3}}{\sqrt{x+3}}\right| + C \;=\;\tfrac{1}{3}\ln\left|\sqrt{\frac{x-3}{x+3}}\right| +C[/tex]
. . [tex]=\;\tfrac{1}{6}\ln\left|\frac{x-3}{x+3}\right| + C[/tex]
How does $\frac{1}{x^2-9}$ simplify to $\frac{1}{6}( \frac{1}{x-3}-\frac{1}{x+3})$? I see that $x^3 - 9 = (x - 3)(x + 3)$ but how is this derived?
We use partial fraction decomposition. We begin with the factorization:
$$\frac{1}{x^2-9}=\frac{1}{(x+3)(x-3)}$$
Then the assumption this factored form can also be written in the following form (sum):
$$\frac{1}{(x+3)(x-3)}=\frac{A}{x+3}+\frac{B}{x-3}$$
Now, I would at this point, for simplicity since we have linear factors, use the Heaviside cover-up method. On the left side, we see the root of the first factor is:
$$x=-3$$
Then we cover-up that factor, and evaluate what's left using that value for $x$ and equate that to $A$:
$$A=\frac{1}{-3-3}=-\frac{1}{6}$$
Then we do the same thing with the other factor for $B$:
$$B=\frac{1}{3+3}=\frac{1}{6}$$
And so, we obtain:
$$\frac{1}{(x+3)(x-3)}=\frac{-\dfrac{1}{6}}{x+3}+\frac{\dfrac{1}{6}}{x-3}=\frac{1}{6}\left(\frac{1}{x-3}-\frac{1}{x+3}\right)$$
Back when I was a student, one of the standard forms we learned was:
. . [tex]\int\frac{du}{u^2-a^2} \;=\;\frac{1}{2a}\ln\left|\frac{u-a}{u+a}\right| + C[/tex]
It occupied only a few brain cells and saved hours of time.
